Lower Control Arm replacement - Page 2 - Toyota FJ Cruiser Forum
 10Likes
post #11 of 16 (permalink) Old 01-11-2017, 01:48 PM
Joabmc's Avatar
Quoted: 593 Post(s)
Re: Lower Control Arm replacement
Part numbers as per @bandi
He has them listed for 07-09 & 10-14
Rearward Cam Parts
48190 CAM ASSY, CAMBER ADJUST, QTY RQD 2
48190-60020 (01/2006 - 07/2009)
48190-60040 (08/2009 - 10/2010)
48198 CAM, CAMBER ADJUST, NO.2, QTY RQD 2
48198-60011 (01/2006 - 07/2009)*
48198-60020 (08/2009 - 10/2010)
NUT, QTY RQD 2
90178-16007 *** STD. PART* *
or
90179-14069 *** STD. PART
(note both LH & RH are the same, even tho' description list LH & RH)
48655D BUSH, FRONT LOWER ARM, NO.2 RH, QTY RQD 1
48655-60030 (01/2006 - 07/2009)
48655-60050 (08/2009 - 10/2010)
48655E BUSH, FRONT LOWER ARM, NO.2 LH, QTY RQD 1
Frontward Cam Parts
48452B PLATE, FRONT SUSPENSION TOE ADJUST, NO.2, QTY RQD 2
48452-35020 (01/2006 - 07/2009)
48452-60020 (08/2009 - 10/2010)
48409D CAM SUB-ASSY, FRONT SUSPENSION TOE ADJUST, QTY RQD 2
48409-60020 (01/2006 - 07/2009)*
48409-60040 (08/2009 - 10/2010)
BOLT, QTY RQD 2
90119-14120 *** STD. PART
or
90119-16005 *** STD. PART
48654E BUSH, FRONT LOWER ARM, NO.1 RH, QTY RQD 1
48654-60030 (01/2006 - 07/2009)
48654-60050 (08/2009 - 10/2010)
48654F BUSH, FRONT LOWER ARM, NO.1 LH, QTY RQD 1
bandi likes this.
Joabmc is offline
post #12 of 16 (permalink) Old 01-12-2017, 05:57 AM
cwheeler's Avatar
Quoted: 68 Post(s)
I got my stuff from rockauto.
cwheeler is offline
post #13 of 16 (permalink) Old 01-12-2017, 07:05 AM
Sanderhawk's Avatar
Quoted: 963 Post(s)
$1200 for a brake job!!!! Brand new pads and 2 new rotors only cost me $180. Brake job is easiest thing to do on a FJ.
thane and cliffy like this.
Steve.... 07 FJ with almost enough mods.... August 2017 Member of the month
Sanderhawk is online now
post #14 of 16 (permalink) Old 03-14-2018, 02:00 PM
TSnider's Avatar
Quoted: 49 Post(s)
for anyone in the future doing this. i used a fireproof blanket and stuffed it up above the LCA to block heat from hitting anything i didn't want it to get to, and cut the bolts out that way. there's barely enough room. I didn't cut the bolt heads off, rather in between the mounting points and the LCA. you'll burn a little rubber.
fire blanket is necessary.
debFJVT likes this.
TSnider is offline
post #15 of 16 (permalink) Old 03-14-2018, 05:02 PM
Admin
Winterpeg's Avatar
Quoted: 2401 Post(s)
If you are doing the LCA replacement because of the lower ball joints.... it's possible to press out the joints and replace them with a Moog joint.
I had my mechanic do this. He did it with the LCA's still on the FJ.
Suck it up... it's only -40
2008 FJ Trail Teams
ARB Front; Exp1 rear STC; Apex rocksliders; Lightforce on front bumper; ARB Full Rack w/Grid; ; Icon Susp w/cdc; magnaflow muffler (mashed the original); Engo 12000S winch; 285/75/16 Duratracs; Ricochet skids, Uniden PC78 Elite CB (ch 16 typically, ch 19 on the hwy)
"Don't drive angry".... BFM
Winterpeg is offline
post #16 of 16 (permalink) Old 03-15-2018, 08:28 PM
Quoted: 2 Post(s)
I replaced the upper and lower control arms on my 2007 model with Total Chaos CAís with uniball joints. My FJ was lifted but left with the stock control arms by the previous owner. The change of angle prematurely wore out the stock ball joints and bushings.
I first changed the uppers about three years ago, changing both in about 3 - 4 hours. The uppers are easier than lowers as you donít have the lower strut connection to have to bolt in with both frame pivot connections.
A year or so later I bit the bullet with the LCAís, which took about 5 - 6 hours working by myself. It was a little frustrating as I had to compress the strut with a second floor jack enough to fit both frame pivots, and the lower strut connection in place at the same time. Anyway, I got it done and didnít risk my Christianity too much - I did say a prayer asking forgiveness when I finished though just to be safe!
The Total Chaos are a supreme fit with neoprene greasable bushings and uniball joints impregnated with high-tech aerospace-type lubrication. They donít require lubrication until they near the end of their lifespan but I go ahead and shoot them with Tri-Flow (recommended lube) when I grease the bushings at each 7,500 mile oil change (full synthetic).
Not sure why you need a $1,200 brake job but siding with others posting here I definitely suggest you at least investigate doing the brakes yourself and saving potentially almost $1,000.
ToyotaFanatic1 is offline
