2007 FJ and KING suspension - Toyota FJ Cruiser Forum
 2Likes
  • 1 Post By mikey
  • 1 Post By jamesepoop
post #1 of 7 (permalink) Old 07-03-2017, 06:41 PM Thread Starter
mikey's Avatar
Quoted: 1469 Post(s)
On a 2007 FJ
KING front coilover
Where do the brackets for the reservoirs mount?
Thanks
"It's not easy being Green"
Kermit the Frog
mikey is offline
post #2 of 7 (permalink) Old 07-03-2017, 07:17 PM
jamesepoop's Avatar
Quoted: 1107 Post(s)
Re: 2007 FJ and KING suspension
@mikey i think they have different angled mounts depending on which model, adjusters or not. My resis with adjusters attach to the sway bar mount and act as a spacer if I decided to use the sway bar.
Iconic_ previously said:
LEDLIYFJL: Live Every Day Like Its Your FJ's Last
Mad Maxxine Build - 2007 Fresco Silver Metallic
My Travels: http://www.downtownfotos.com
jamesepoop is offline
post #3 of 7 (permalink) Old 07-03-2017, 07:21 PM
Sanderhawk's Avatar
Quoted: 977 Post(s)
I have non adjustable King shocks on my 07 and the resi brackets are also mounted under the sway bar mounts
Steve.... 07 FJ with almost enough mods.... August 2017 Member of the month
Sanderhawk is offline
post #4 of 7 (permalink) Old 07-03-2017, 09:03 PM Thread Starter
mikey's Avatar
Hmmmm.......I removed the sway bar and the hardware is long gone.
Kermit the Frog
mikey is offline
post #5 of 7 (permalink) Old 07-04-2017, 08:16 AM
Sanderhawk's Avatar
Quoted: 977 Post(s)
I bet you could just get a couple of bolts and thick washers and they would still mount up just fine I don`t think the sway bar mounts are holding the bracket on I think that's just where the brackets needed had the room to go so they put them under the sway bar mounts.
post #6 of 7 (permalink) Old 07-04-2017, 09:11 AM Thread Starter
mikey's Avatar
Cool, if I pull the trigger on these it will another trip to the bolt isle at Home Depot.
Sanderhawk likes this.
Kermit the Frog
mikey is offline
post #7 of 7 (permalink) Old 07-04-2017, 01:43 PM
jamesepoop's Avatar
Mine came with allen bolts to install the resi mount. I think you'll be okay unless you want to install front sway bars
Loganbeere likes this.
