Suspensions: DIY vs Pro Install - Page 5 - Toyota FJ Cruiser Forum
 100Likes
post #41 of 85 (permalink) Old 04-15-2019, 08:10 PM Thread Starter
FJFool's Avatar
Quoted: 246 Post(s)
Re: Suspensions: DIY vs Pro Install
I used a pair of 1.5" x 15' 4,000LB-rated ratcheting straps. Looping them down the middle and around the outside opposite of each other, careful to leave the ends of the springs unbound so that the straps would not be pinned against anything, I ratcheted them down equally (to prevent bulging in either direction) until the spring was compressed just enough to allow me to install it. Leaving the straps on, I jacked up the rear axle until it compressed the spring more than the straps, thereby causing the straps to go slightly slack. This allowed me to remove the straps with ZERO DANGER. I did this one side at a time. I wish I had taken pics of this process to better explain it
Apparently, this is a thing. I'm not the first to use this method. Googling it yeilded several video examples. BUT it was an independent discovery on my part, so I'm still a genius.
—MIKE
Two roads diverged in a wood, and I,
I took the one less traveled by,
And that has caused all the damage to my FJ.
~ Robert Frost
42" Light Bar | Warrior Products Roof Rack | N-Fab RSP Bumper | ARB Skids | 4.0L V6 AT | ToyTec BOSS 2.0 Coilovers | Sway Bar Relocate | Toytec Superflex Heavy Duty Rear Coils | Toytec BOSS Rear Shocks | SPC Adjustable UCAs | Toytec Rear Aluminum 2" Bump Stop Kit | 265/70R/17 Toyo ATs x5 | 2" Wheel Spacers | Rad Rubber Designs Engine Splash Guards | Hi-Lift Extreme Jack
FJFool is online now
post #42 of 85 (permalink) Old 04-16-2019, 08:20 PM
Slonomo's Avatar
Quoted: 12 Post(s)
Oh...one more suggestion....DO NOT, EVER, EVER, NEVER, EVER USE CINDER BLOCKS OR CONCRETE BLOCKS, OR BRICKS!!! instead of jack stands!!! PLEASE!
debFJVT and FJFool like this.
2008 FJ Cruiser, Stock for now. Not a wheeler but will be.
Slonomo is offline
post #43 of 85 (permalink) Old 04-16-2019, 08:26 PM
Firemedic831's Avatar
Quoted: 476 Post(s)
Slonomo previously said: View Post
. Job Security
FJFool and CabinCruiser like this.
09 AT Toytec Boss performance 3inch lift, Demello sliders , TRD brakes , MT offset Lower links . Rad Rubber splash guards ,Cobra CB,
Firemedic831 is offline
post #44 of 85 (permalink) Old 04-16-2019, 10:20 PM
AJsC4's Avatar
Quoted: 45 Post(s)
FJFOOL said :"6) Spray everything with penetrating oil. Even components nearby you don't anticipate needing to remove or adjust. At the very least, spray it all once a week before install, again the day before, and again the day of. I used PB Blaster. I'm convinced that, had I not used it, I would not be standing here today."
just a thought.
I have had great success with 50/50 mix of acetone and automatic transmission fluid..put in spray bottle and apply to bolts....found this somewhere on a search...worked great..but need to do it for a few days also as recommended above......
FJFool likes this.
2012 Titanium Auto
All-Pro (dual-color G/B) Rails
Sprngtail Sde&R M-pacs kwik-fist w Mgnalght
Fire Ext, First Aid
Rmote strt
Fjtoyman shock skids, Safari Snrkl
Boztec R Diff Skid, Full set Richochet orange skids
Green wrap
sPOD, DiHrd AGM
Rgd lght bar e-series dually 20 and 10x2..
AeroFlow Hdlight guards, W Okole cvs
Bandimount w Firestick II & Uniden CB
Baja Drp-in Bskt, Pwr Tank
Hi-Lift w Fourtreks
Lght Rcing UCA's, All-Pro R U/L Links
Toytec Ult. Lift, Icon PH Bar
Scuba Mod
All-Pro guss Spndls, BMC
Demllo F Alum Bmpr w TJM 10K wnch & Acros VisionX 6.7 Lght Cannons, Pro-link
Exp 1 R Swngout Bump w Rugg Rdge lghts
Spidrtrax
Birddog Rims
GoodYear MT/R 285/70/17's
AJsC4 is offline
post #45 of 85 (permalink) Old 04-17-2019, 11:12 AM Thread Starter
FJFool's Avatar
Quoted: 246 Post(s)
Prius2FJ previously said: View Post
After my ordeal with a shop, DIY is the way to go. Looking forward to seeing your lift FJFool!
Finally, some worthy pics of the lift:
Suspensions: DIY vs Pro Install-lift-01.jpg
Suspensions: DIY vs Pro Install-lift-02.jpg
Suspensions: DIY vs Pro Install-lift-03.jpg
If you're noticing the dent in the fender, I haven't swapped it out yet. But the hood is done. (Old one is in the background of the 2nd pic)
debFJVT, CabinCruiser and Prius2FJ like this.
—MIKE
~ Robert Frost
post #46 of 85 (permalink) Old 04-17-2019, 11:44 AM
fka BLACK HAWK
NyNomad's Avatar
Quoted: 373 Post(s)
i've done all of my suspension installs myself. the only difference if i had paid a shop to do it is they have power tools.. but there's limited to no power tools on the trail if i happen to break something. Good learning experience
SilvFx and FJFool like this.
" You can't be afraid to scratch it "
NyNomad is offline
post #47 of 85 (permalink) Old 04-17-2019, 11:59 AM
mikey's Avatar
Quoted: 1446 Post(s)
FJFool previously said: View Post
Attachment 1075924
Attachment 1075926
Attachment 1075928
The lights - 2x Flood and 2x Spot?
"It's not easy being Green"
Kermit the Frog
mikey is offline
post #48 of 85 (permalink) Old 04-17-2019, 01:43 PM Thread Starter
FJFool's Avatar
Quoted: 246 Post(s)
All flood on the bottom, though I like your idea.
The two in the middle may end up being temporary as I'm playing around with the idea of having a welder modify this bumper to include a receiving hitch right there so I can mount a winch as needed.
—MIKE
~ Robert Frost
post #49 of 85 (permalink) Old 04-19-2019, 02:17 PM
Boabrother4's Avatar
Quoted: 18 Post(s)
FWIW, Design as if the winch will live up front on that bumper as it will be there 99% of the time it is with you, the FJ rear departure angle will not allow it to be carried in the rear off road. Consider any cooling restrictions, consider access/removal of winch, consider any effect on approach angles. Wiring is easy with welding wire and forklift battery connectors. This is what I did for my Willy's, I will also add a mount to the roll cage just in case (not applicable for FJ's).
FJFool likes this.
2011 Brick
Boabrother4 is offline
post #50 of 85 (permalink) Old 04-19-2019, 02:44 PM Thread Starter
FJFool's Avatar
Quoted: 246 Post(s)
Boabrother4 previously said: View Post
I could be missing something, but I planned on keeping the winch inside the FJ 99% of the time, bringing it out mounted on one of these and plugging it in front or rear only when I need it:
Suspensions: DIY vs Pro Install-capture20190419134150797.png
CabinCruiser likes this.
—MIKE
~ Robert Frost
Tags
diy , how to , lifts , suspension
  Similar Threads
DIY suspension/lift install thread somewhere???? g-Know Suspension / Steering Tech 9 12-13-2012 10:39 PM
All Pro rear bumper tow hitch install help tripenboy Interior / Exterior Visual Tech 2 05-25-2011 04:05 PM
All Pro bumper install OFRD_GRL 4x4 / Off-Road Tech 90 02-01-2007 12:15 AM
