Remote Reservoir Pros & Cons - Page 2 - Toyota FJ Cruiser Forum
 36Likes
post #11 of 24 (permalink) Old 04-12-2019, 03:01 PM
jeppacrzy's Avatar
Quoted: 14 Post(s)
Re: Remote Reservoir Pros & Cons
For casual driving / wheeling, yeah, you donít need them IMO. Iím not in that camp and like to drive faster for extended times on dirt roads / desert. I have a 2012 TT and have actually seen how long it takes to fade the stock shocks and get less than desirable results. You would probably do better and not need to upgrade later if you went with a larger shock body (2.0 or 2.5) with out a resi IMO
Irving Zisman likes this.
2012 TT , 2.5 Fox DSC Rear , SAW Rear Springs, CB, BajaDesigns Squadron Pro
jeppacrzy is offline
post #12 of 24 (permalink) Old 04-17-2019, 11:51 AM
fka BLACK HAWK
NyNomad's Avatar
Quoted: 373 Post(s)
debFJVT previously said: View Post
In my opinion (and based on opinion and real-time testing of some experts I know) remote reservoirs are overrated for all but the few who do desert racing. The resis allow more oil volume and more rapid cooling so the response doesnít fade. Many people get resis because they think it looks cool and figure it canít hurt. Personally Iíd rather spend that mod money on other things. In your case I think it would be a waste, so buy the best suspension you can. Which Toytec lift are you considering? I have the Boss 2.5 up front and Radflo long travel rear and itís fantastic, both for hard wheeling and on the street. The Boss kit uses Radflo shocks front and rear and are excellent, as is Toytec in general.
i've been preaching this for years now. The reservoir is there so that when the oil has a place to go for heat expansion caused by HIGH cycle rates and long strokes. Daily driving, trail rides and rock crawling don't cause the oil the heat up enough to make the reservoirs effective. IF you want inexpensive and good quality front suspension with a warranty i recommend Bilstein 6112's. If i didn't love high speed desert driving and didnt get my Kings i would have gotten the 6112's.
jeppacrzy and jamesepoop like this.
" You can't be afraid to scratch it "
NyNomad is offline
post #13 of 24 (permalink) Old 04-22-2019, 03:48 AM
jeppacrzy's Avatar
Quoted: 14 Post(s)
NyNomad previously said: View Post
^^^ exactly.
post #14 of 24 (permalink) Old 04-22-2019, 08:44 PM
A-Team Moderator
Hannibal's Avatar
Quoted: 2594 Post(s)
Exclamation
Complaint rec'd for thread crapping. All related posts were removed. I refer you all to the rules regarding such.
NyNomad and Thorn661 like this.
トヨタ
Hannibal is offline
post #15 of 24 (permalink) Old 04-22-2019, 10:11 PM
shrdnar's Avatar
Quoted: 148 Post(s)
Definitely solid advice in here... as Deb mentioned, a handful of us, myself included, run the ToyTec Boss 2.5s (radflos) all around. One thing I didn't see mentioned regarding the 2.5s is that they are fully serviceable and re-buildable, and as far as I know (maybe others can verify) the reservoirs can be added on later.
If I were in your shoes, I'd go for non-resi 2.5s now and see how they ride first. If they aren't enough for your style of off-roading, or when the time comes to service them, you can pay a little extra to add on the reservoirs then.
debFJVT likes this.
shrdnar is offline
post #16 of 24 (permalink) Old 04-22-2019, 10:51 PM
Firemedic831's Avatar
Quoted: 485 Post(s)
Correct With the Toytech 2.5 you can add Resi later . You will need to send them to Radflo to do it (they are a Radflo Shock ) You can also add the compression adjusters .
debFJVT and Thorn661 like this.
09 AT Toytec Boss performance 3inch lift, Demello sliders , TRD brakes , MT offset Lower links . Rad Rubber splash guards ,Cobra CB,
Firemedic831 is offline
post #17 of 24 (permalink) Old 04-23-2019, 01:57 AM
MOAB SUPERSTAR
debFJVT's Avatar
Quoted: 2088 Post(s)
shrdnar previously said: View Post
Firemedic831 previously said: View Post
I spoke with Toytec months ago who said they were probably getting into the shock rebuilding business, so hopefully (for those of us living east of the Mississippi) we can send direct to Toytec for that, and/or addition of resis.
Thorn661 likes this.
Member of the Month November 2016
TLCA# 25170
debFJVT is offline
post #18 of 24 (permalink) Old 04-23-2019, 05:12 PM
jeppacrzy's Avatar
Quoted: 14 Post(s)
Yeah, add resi later but it will cost you the amount for the resi plus labor plus time off vehicle. I had the same dilemma before I got mine and thought I didnít want to have to want to upgrade later so I got the Fox w/ DSC so there is no upgrade path unless I got FT which is another beast all together.
post #19 of 24 (permalink) Old 04-23-2019, 05:24 PM
Iconic_'s Avatar
Quoted: 2522 Post(s)
But if you need them rebuilt anyway. Might as well.
debFJVT likes this.
Iconic_ is offline
post #20 of 24 (permalink) Old 04-23-2019, 07:13 PM
jamesepoop's Avatar
Quoted: 1091 Post(s)
If you do any performance driving, I recommend it. This includes crawling which still puts your shocks at work and gets the oil/nitrogen moving.. Think of the reason they make a 2.5 vs 2.0 shocks. You want the larger capacity if the budget allows it, go for it. If it doesn't then go with what you can afford. Maybe the most performance driving you get is to the mall in a hurry, then I'd suggest the non-resi and a 2.0 shock will suffice.
jamesepoop is online now
  Similar Threads
Icon remote reservoir vs. Windshield fluid fender plastic big green egg Suspension / Steering Tech 2 06-15-2014 12:20 PM
3" Lift pros and cons steve n ky Suspension / Steering Tech 11 12-13-2013 06:04 PM
Nitto Terra Grapplers - Pro's and Con's? dickdog75 Wheels and Tires 13 01-06-2012 04:55 PM
Budbuilt or Ricochet Skids? Pros and Cons? Brian7758 4x4 / Off-Road Tech 36 07-20-2011 12:23 PM
Spare tank on my ARB roof rack. Pros? Cons? Aim4myhead 4x4 / Off-Road Tech 6 10-31-2007 11:34 AM
