Steering Wheel Vibration on Rugged Terrain - Toyota FJ Cruiser Forum
 2Likes
  • 2 Post By Bert
post #1 of 8 (permalink) Old 07-09-2019, 02:19 PM Thread Starter
Quoted: 2 Post(s)
Hey Guys
Ive been fighting this problem since the day I got my 2011 FJ.
On normal roads it drives so well even on speeds above 80
But when offroading (Rocky roads, bumps and holes or even small stones) my steering wheel shakes!
I know that FJ's don't come with front axles so no steering stabilizers can be fitted.
So what should I do? Is this normal?
CrusoeRamy is offline
post #2 of 8 (permalink) Old 07-09-2019, 02:39 PM
TexasFJ's Avatar
Quoted: 52 Post(s)
Re: Steering Wheel Vibration on Rugged Terrain
So, .....
the wheel shakes when on rough surfaces? that's pretty much normal for every vehicle out there without steering-by-wire. Unless I'm missing something here, every vehicle I've driven on a rough road will shake the steering wheel. Solid axle, IFS with and without a steering stabilizer, 2wd with and without a steering stabilizer, 4x4's, ATV's, ATC's, cars, mountain bikes....
There's a pretty direct link between the steering linkages and the steering column. Yes, there are gears and pumps in the mix but the forces do get transmitted to the column. So anything that disproportionately affects one wheel over the other will cause "feedback" or wheel shake to a degree. If you are looking at the wheel during the shaking, is it more like a rapid left/right turning motion or like the steering wheel is moving towards and away from you?
What doesn't kill me makes me more cynical.
TLCA #26213
TexasFJ is offline
post #3 of 8 (permalink) Old 07-09-2019, 02:45 PM Thread Starter
Quoted: 2 Post(s)
TexasFj
Yes! it's a rapid left right movement on rugged roads
post #4 of 8 (permalink) Old 07-09-2019, 06:12 PM
TexasFJ's Avatar
Quoted: 52 Post(s)
Well, to me that sounds normal. Maybe someone else knows something else or Im not asking the right question. But if the wheel was shaking on smooth tarmac Id say something is wrong. On trails with rocks and gravel and stones, sure the shaking is totes normal.
Now if you hear a ping then the shaking goes completely away and turning the wheel does nothing, then you have a problem
TLCA #26213
TexasFJ is offline
post #5 of 8 (permalink) Old 07-10-2019, 07:29 AM
Cholerabob's Avatar
Quoted: 217 Post(s)
"Rugged terrain" ... Rugged driving...
Bilsteins 5100, Metal Tech Rear Long Travel, Camburgs Balljoint UCAs, Full Ricochet Skid Plates, All Pro Sliders, RESZ Fab rear LCAs , Luna Dual Battery, Cooper STT PRo 35s on 16' Mickey Thompson Classic Baja Locks, FJToyman Shock Skids, Total Chaos lower link Skids, Boztec Dif Skid, Exp1 front Diamond Bumper, Exp1 Rear Bumper with Carrier, Viper winch, Ricochet Lighted Air Dam
Cholerabob is online now
post #6 of 8 (permalink) Old 07-10-2019, 08:58 AM
crazysanman's Avatar
Quoted: 197 Post(s)
When I'm on a bumpy road at any speed I get a "banging" from the steering wheel that feels like there is a big steel rod in the steering column that's vibrating and bouncing around and I'm feeling the shock from it's impacts. It only recently started happening. I got new tires and it seemed to go away for a thousand miles or so but now it's back.
2012 Army Green "The Mule"
My Build / My Adventures
My YouTube Channel: Chicken River Offroad
http://www.chickenriveroffroad.com
crazysanman is offline
post #7 of 8 (permalink) Old 07-10-2019, 10:13 AM
fka Memphibious FJ
Bert's Avatar
Quoted: 59 Post(s)
I have the same situation, but along with the shaking steering wheel, I have a strange adrenalin rush and uncharacteristic mood improvement. Strangely, all of these symptoms only increase the faster I go.... I am baffled as to why...
TexasFJ and DubstepPear like this.
Bert is offline
post #8 of 8 (permalink) Old 07-10-2019, 10:23 AM
mikey's Avatar
Quoted: 1442 Post(s)
crazysanman previously said: View Post
Have checked the usual suspects? Ball joints, bushings etc?
I did have a little intermittent banging going on - turns out one of front LCA cam bolts was a smidge loose. Quick spin with the torque wrench and all is well.
"It's not easy being Green"
Kermit the Frog
mikey is online now
