The General Rough Country 6 inch lift thread... - Page 16 - Toyota FJ Cruiser Forum
 2Likes
post #151 of 158 (permalink) Old 01-08-2019, 01:53 AM
New west fj's Avatar
Quoted: 1 Post(s)
I would also like those part numbers if anyone has them please ?
New west fj is offline
post #152 of 158 (permalink) Old 01-08-2019, 04:33 AM
FinnJ's Avatar
Quoted: 237 Post(s)
Re: The General Rough Country 6 inch lift thread...
New west fj previously said: View Post
My setup: https://www.fjcruiserforums.com/foru...50-post58.html
FOX 883-02-555 would work too, I think they wonít make -044 anymore.
2007 FJ Cruiser 6M/T CNG TRD Supercharged
My buildup thread
1981 Land Cruiser BJ42 Diesel (under progress)
FinnJ is offline
post #153 of 158 (permalink) Old 06-12-2019, 12:31 AM
Quoted: 4 Post(s)
My RC Differential drop bracket is broken. Did somebody have the same problem, and how could this issue be solved for good?
Greetings
Cookie0-1 is offline
post #154 of 158 (permalink) Old 06-12-2019, 04:51 AM
FinnJ's Avatar
Quoted: 237 Post(s)
Cookie0-1 previously said: View Post
How it is broken? I fixed mine when it was new: https://www.fjcruiserforums.com/foru...ml#post2274209
My buildup thread
FinnJ is offline
post #155 of 158 (permalink) Old 06-13-2019, 01:32 AM
Quoted: 4 Post(s)
I have looked at your thread, but I think this is another location at the differential. I talk about the bracket close to the driveshaft.
It is the following part (circle) and is located at the red x:
The RC picture:
And now the real life:
on the top/left side the part which comes from Rough Country, an the down/right side the Toyota part. The RC part is brocken on both sides between the bushing and the bolt. For me it seems to be to thin in relation to the Toyota part. The thickness of Toyo is 14 mm, the RC is 6 mm and is obviously a cheap, inadequate part.
The other side, the attachment point in the crossmember
Any suggestion?
post #156 of 158 (permalink) Old 06-15-2019, 08:41 AM
KAOS_FJ's Avatar
Quoted: 2 Post(s)
I have changed that same bushing twice due to cracking, I was using upper shock bushings (with a little modifying) to replace it. I finally ordered the correct bushing from Rough Country and noticed itís now made of Poly. I havenít installed yet. Perhaps the Poly bushing is too hard/rigid to soak up any vibrations causing bracket failure? Just to clarify, my bracket never failed, just rubber bushing cracking.
KAOS_FJ is offline
post #157 of 158 (permalink) Old 06-15-2019, 11:48 AM
FinnJ's Avatar
Quoted: 237 Post(s)
I have installed another rubber bush between the original mounting and bolt/washer (inside the cup). It’s not anymore iron against iron.
I have had any problems, 7 years/100.000 miles driven with this setup.
My buildup thread
FinnJ is offline
post #158 of 158 (permalink) Old 06-16-2019, 10:31 PM
Quoted: 4 Post(s)
The (upper) bushing looks ok.
FinnJ previously said: View Post
This sounds good, I will try this. Thanks
Greetings
