HOW TO: Locking Glovebox Mod - Page 5 - Toyota FJ Cruiser Forum
Tech Articles Staging Area All articles which are not finalized should be started in here.
 74Likes
post #41 of 49 (permalink) Old 02-04-2019, 05:20 PM
Quoted: 9 Post(s)
Re: HOW TO: Locking Glovebox Mod
This gave a basic idea of how to rekey an auto lock:
Turbokidd is offline
post #42 of 49 (permalink) Old 02-13-2019, 03:12 PM
i12c's Avatar
Quoted: 63 Post(s)
I got 4/5 tumblers to go back inside the cylinder lock. Trial and error. Youtube videos did help with understanding the process, but it was still a PITA.
1. The worst part was seperating the plastic back in order to even get to the cylinder. A really small, thin flathead screw driver helped pry without breaking.
2. Then, I had to monkey around with the orientation of the parts because I did not take pictures of the "before" assembly. I actually had to use the original latch for reference when the tensioner spring fell out.
3. Another tricky part was understanding that the spring loaded tumblers had to be held down while inserting the key to see if the coding was correct. Do the ones closest to the key entrance first. It is the process of elimination for both top and bottom tumblers. Then move on to the next series.
4. It looks good and beats paying a locksmith $40, but after all I saw of the mechanism structure, I wouldn't count on it keeping out anything but honest passersby and window shoppers.
5. After reading up on other forums, I recommend keying it to a non-chipped non-starting copy of the ignition key to keep hidden in the truck so that you can open the glovebox while driving but which a carjacker can't use to start it. My ignition keys all work as well as my non-chipped emergency key. Not bad for $13 and an hour of trial-and-error while watching T.V. Here is another video:
https://youtu.be/NI8fPZqH6UM
ID:	1067838   Click image for larger version
FJFool likes this.
i12c is offline
post #43 of 49 (permalink) Old 02-13-2019, 04:26 PM Thread Starter
Iconic_'s Avatar
Quoted: 2553 Post(s)
i12c previously said: View Post
5. After reading up on other forums, I recommend keying it to a non-chipped non-starting copy of the ignition key to keep hidden in the truck so that you can open the glovebox while driving but a carjacker can't use to start it.
Just FYI '07's don't have chips in the keys. But good idea, another reason why mine is keyed differently in my '07.
Iconic_ is offline
post #44 of 49 (permalink) Old 02-13-2019, 08:42 PM
Tonka Cruiser's Avatar
Quoted: 280 Post(s)
Great thread and find
Iconic_ likes this.
Tonka Cruiser is offline
post #45 of 49 (permalink) Old 02-15-2019, 08:55 PM
Quoted: 6 Post(s)
This was probably one of the easiest mods I've done to this rig, so far! Agree with other users; this won't keep anyone, determined, out of your glove box. For $14.00 and 15 minutes of your time, well worth it!!
Iconic_ and mk3 like this.
PLC92084 is offline
post #46 of 49 (permalink) Old 03-28-2019, 12:52 PM
.FJ
.FJ's Avatar
Quoted: 39 Post(s)
Well I finally found a black one but it was $33. Seems like the market adjusted to this new found wisdom. Still worth it, especially considering my FJ isnt very secure anymore now that its roofless.
FJ'ed in IL, MO, OR, AZ, TX
2007 Black Diamond (roof fell off) caged.
2014 Iceberg
.FJ is offline
post #47 of 49 (permalink) Old 06-27-2019, 03:56 PM
7T7
Quoted: 0 Post(s)
Thank you Iconic_ 👍
IDFJ and Iconic_ like this.
7T7 is offline
post #48 of 49 (permalink) Old 06-27-2019, 04:44 PM
mikey's Avatar
Quoted: 1462 Post(s)
Just opened my glove box for the first time in ~4 years......found my ipod and a bunch of visitor badges from a customer in Houston that I forgot to turn in.
bazross likes this.
"It's not easy being Green"
Kermit the Frog
mikey is offline
post #49 of 49 (permalink) Old 07-01-2019, 11:02 AM
MOAB SUPERSTAR
debFJVT's Avatar
Quoted: 2112 Post(s)
Just did this and was lucky to get one with a key off eBay...and the threaded holes matched OE so it was literally two screws and done! Awesome mod, and huge thanks to you Iconic
bazross and Iconic_ like this.
Member of the Month November 2016
TLCA# 25170
debFJVT is offline
  Toyota FJ Cruiser Forum > FJ Cruiser Technical Articles & Buyers Guides > Tech Articles Staging Area
