Trans temp in Torque Pro - OBDII...anyone try this? - Toyota FJ Cruiser Forum
 10Likes
post #1 of 33 (permalink) Old 06-08-2014, 10:20 AM Thread Starter
miketx's Avatar
Quoted: 43 Post(s)
I found this in a Tacoma and then a Tundra forum, but didn't find it here....maybe I didn't search long enough.
Anyone using this with Torque Pro? I'm going to try it sometime soon.
Trans temp settings for Toyota / Torque Pro:
For pre 2010 cars (all equations copied from the thread at the Torque forum)
In Torque enter:
OBD2 Mode and PID:
21d9
Long Name:
Transmission Fluid Temperature 1 (or what you like)
Short Name:
Trans 1
Minimum Value:
0.0
Maximum value:
300.0
Scale factor:
x1
Unit Type:
F (or alternatively C is you use the second equation below)
Equation:
((((E*256)+F) * (7/100) 400)/10) for output in F
or alternatively
(((((E*256)+F) * (7/100) 400)/10) 32) * (5/9) for output in C
OBD Header to use:
left blank
For 2010+ cars (do not own one, so I have not tested this)
OBD2 Mode and PID:
2182 (NOTE DIFFERENT PID for newer Toyotas)
Long Name:
Short Name:
Trans 1
Minimum Value:
0.0
Maximum value:
300.0
Scale factor:
x1
Unit Type:
F
Equation:
((((A*256)+B) * (7/100) 400)/10)
you can also convert this equation to C as above
OBD Header to use:
left blank
breagles and sunsetrider737 like this.
08 Supercharged TT
miketx is offline
post #2 of 33 (permalink) Old 06-08-2014, 11:36 AM
RoverGGM's Avatar
Quoted: 86 Post(s)
Re: Trans temp in Torque Pro - OBDII...anyone try this?
I have the app, but I have a 2012. Curious as to how it works for the earlier years.
RoverGGM is offline
post #3 of 33 (permalink) Old 06-08-2014, 04:25 PM Thread Starter
miketx's Avatar
Quoted: 43 Post(s)
You could try the 2010+ setup above.
I just tried the pre 2010 setup and it works! Sitting at idle, warm engine, the trans was running about 147 degrees. Sounds about right, since the fluid is flowing through the radiator.
08 Supercharged TT
miketx is offline
post #4 of 33 (permalink) Old 07-03-2014, 08:41 AM
sbarr's Avatar
Quoted: 17 Post(s)
I used the 2010+ code in my 2013 and it appears to be working. No way to independently verify if the temperature it is displaying is correct, but it is producing a reading. This morning it was giving about 145 degree F trans temp with the water temp being about 180.
sbarr is offline
post #5 of 33 (permalink) Old 07-13-2014, 06:34 PM
Quoted: 1400 Post(s)
sbarr -
You stated that you "used the 2010+ code in my 2013..".
Where did you locate the PID info for the 2010+ models?
I need to get setup to monitor transmission temp on a 2014 FJ.
Also, what hardware did you use to interface with the OBD-II system? A plug-in Bluetooth module? If so, which one?
FJtest is online now
post #6 of 33 (permalink) Old 07-14-2014, 06:53 AM Thread Starter
miketx's Avatar
Quoted: 43 Post(s)
Hi FJTest,
The PID is the one listed in the code (2182).
A bluetooth enabled ELM327 reader is the way to go. This is what I have, but there are many others.....but they are all pretty much the same.
Amazon.com: ELM 327 Bluetooth Obdii Obd2 Diagnostic Scanner, Elm327 Wireless OBD 2 Scan Tool Check Engine Light CAR Code Reader: Automotive
08 Supercharged TT
miketx is offline
post #7 of 33 (permalink) Old 04-24-2015, 01:41 AM
Admin
Winterpeg's Avatar
Quoted: 2470 Post(s)
So I got one of the ELM327 Bluetooth dongles from amazon... it's worked a grand total of 2 times. It paired with my phone no problem... worked... then stopped giving me readings... then worked again... now it's not....
My guess is I ended up with a knockoff and with my luck it was built on a Friday afternoon or the lighting in the sweat shop in that particular corner wasn't great.
Does anyone know how to ensure I am buying a legit piece?
I'm guessing these are the guys that originally made them?.....
http://www.amazon.com/Beelike-ELM327...9861072&sr=1-1
.... but in the wide world of Amazon... how do you ensure it's from them and not a cheap knockoff? They're all inexpensive...
Suck it up... it's only -40
2008 FJ Trail Teams
ARB Front; Exp1 rear STC; Apex rocksliders; Lightforce on front bumper; ARB Full Rack w/Grid; ; Icon Susp w/cdc; magnaflow muffler (mashed the original); Engo 12000S winch; 285/75/16 Duratracs; Ricochet skids, Uniden PC78 Elite CB (ch 16 typically, ch 19 on the hwy)
"Don't drive angry".... BFM
Winterpeg is offline
post #8 of 33 (permalink) Old 04-25-2015, 02:46 PM
WP - I'd recommend the BAFX dongle.
It's worked flawlessly with every Toyota vehicle I've attached it to, and paired flawlessly with every Bluetooth device I've tried. I've been using it nearly continuously for months without any issues .
It also has by far the highest positive feedback of all the similar units on Amazon , so others have had similar experience to what I have had .
I also bought a physically "shorter" dongle that would be a better fit in my 3rd Gen 4Runner, with its vertically-oriented OBD-II connector, but although it appears to have "connected" with the vehicle's ECU, and paired with my Android devices, I could never get it to transfer data. I'll stick with the "proven" BAFX unit.
post #9 of 33 (permalink) Old 04-25-2015, 04:32 PM
Admin
Winterpeg's Avatar
Thx!
When I do a search for just "bafx" a few different varieties comes up....
Do I just pick the most expensive one?
http://www.amazon.ca/Bluetooth-CAN-B...&keywords=bafx
Sorry for needing the handholding but I don't see the difference on Amazon and I already have one $20 paperweight.
FJtest previously said: View Post
2008 FJ Trail Teams
post #10 of 33 (permalink) Old 04-25-2015, 06:02 PM
Quoted: 45 Post(s)
Worked for me on my '07.
breagles is offline
  Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Transmissions / Transfer Cases / Traction Aids
