Abs-vcs trac---all lights - Page 2 - Toyota FJ Cruiser Forum
 3Likes
post #11 of 25 (permalink) Old 07-24-2016, 09:16 PM
Desert Moderator
amaclach's Avatar
Quoted: 2919 Post(s)
Re: Abs-vcs trac---all lights
In "normal" conditions, those lights would come on when the vehicle is in 4LL with the rear diff locked. There is a hack that many of us have done, where a switch is put on the diff lock signal circuit, which tells the ecu that the diff is locked, so it turns off all the nannies.
With those symptoms, the first place I would check is the connectors on the e-locker on the rear diff. It shouldn't take more than 5 minutes to check they are firmly seated.
Black '14 6MT
Stock bumpers
Some mods
Rear Diff Lock on Demand mod: https://www.fjcruiserforums.com/foru...mand-hack.html
Nannies Off Mod: https://www.fjcruiserforums.com/foru...ml#post1183262
amaclach is offline
post #12 of 25 (permalink) Old 07-24-2016, 10:11 PM
Bar3K's Avatar
Quoted: 1862 Post(s)
WHOZONDEK previously said: View Post
When it first happened i was pulling a trailer with about 800 lbs. Any ideas.
This could be a start.
Do you have trailer lights?
Is the trailer lights factory?
Bar3K is offline
post #13 of 25 (permalink) Old 07-24-2016, 11:02 PM
LHB
LHB's Avatar
Quoted: 124 Post(s)
You might want to stop by Autozone.
They will read your error codes for free.
Then it's just a matter of finding somebody who can decipher them. I used to be able to half-way do it with BMW's but I don't have enough experience with Toyotas yet.
But if you get the error codes there are people here who can help.
2014 FJ Cruiser. Army Green Urban and Rural 4x4 Assault Vehicle.
*Strength and Honor*
"We few, we happy few, we band of brothers." - Shakespeare, Henry V
"I hate rude behavior in a man. I won't tolerate it." - Captain Woodrow F. Call, Lonesome Dove
"If the police catch me I'll end up in the slammer. 'Cause The Law don't want no gear jammers" - George Thorogood and the Delaware Destroyers, Gear Jammer
LHB is offline
post #14 of 25 (permalink) Old 08-02-2016, 04:10 PM
Quoted: 0 Post(s)
Send a message via AIM to ramiroshelby Send a message via Yahoo to ramiroshelby
Hello I have the same lights come on too, abs-vsc-trac. They intermittent while driving or when I put my foot on the break when coming to a stop. Also sometimes I cant' shift out of park into another gear. I have to push on the breaks a couple of times before it will disengaged out of park and if that does not work then I hit the relaase button to get it out of park. So can I get a little help on what sensors I need to look at. I have a 07 2WD. I know it's not 4WD. Thank you for your help.
ramiroshelby is offline
post #15 of 25 (permalink) Old 08-02-2016, 04:35 PM
AMMO461's Avatar
Quoted: 162 Post(s)
@WHOZONDEK and @ramiroshelby ,
You both need to have your brake light switch checked and probably replaced. When that switch goes bad it will cause ABS,-VSC,TRAC lights to illuminate. It is an easy check/fix to a pain in the button problem. Let us know what you find out.
"Mean Green" '10 Army green 4x4 AT ATRAC/rear locker. Demello 3 hoop w\BD sqd, Smittybilt M1 Gen2, PURE FJ sliders, EXPO-1 Wash Bottle, Ironman FCP-C's front, Boss 2.5 w/ TOYTEC 2.0 HD rear, SPC DOM LCA. 16" BF 285 KO2 E's on Method NV's.
"Angry Orange" '13 Magma 4x4 AT ATRAC/rear locker, CRAWL. Demello 3 hoop Evil Eye w\BD sqd, Smittybilt M1 Gen2, AP sliders, EXPO-1 Wash Bottle, Ironman FCP-C front, Boss 2.5 w/ TOYTEC 2.0 HD rear. SPC DOM LCA's, 17" BF 285 KO2 E's on Method Holes.
AMMO461 is offline
post #16 of 25 (permalink) Old 08-03-2016, 05:00 AM
LRP
LRP's Avatar
Quoted: 17 Post(s)
Mine are off and on as well. been so since I bought it in '12. in winter they come on when it's cold but if I warm it up and then restart it most times they stay off. or if they are off for a while they come on when I get on the highway... Here are the codes I pull when I take it to advanced auto;
C1223
U0073
Control Module Communication Bus Off
U0100
Lost Communication With ECM/PCM "A"
U0123
Lost Communication With Yaw Rate Sensor Module
U0124
Lost Communication With Lateral Acceleration Sensor Module
U0126
Lost Communication With Steering Angle Sensor Module
08 TT
US ARMY RETIRED
LRP is offline
post #17 of 25 (permalink) Old 08-03-2016, 10:35 AM
Coldnapalm's Avatar
Quoted: 6 Post(s)
Send a message via AIM to Coldnapalm
mine came on for a month while i was in Aspen, then they went back off. i dont remember but i think it was something to do with a charcoal filter or something? (just comes to mind may have nothing to do with it)
2007 FJC 6MT
Complete Mods
Vsc Switch
20% tint all around
AllPro 1.5" spacers
old fj link below
Coldnapalm's Rig - Toyota FJ Cruiser Forum
Coldnapalm is offline
post #18 of 25 (permalink) Old 08-06-2016, 06:42 PM
Quoted: 0 Post(s)
Well I took it to my buddy's shop and hooked it up to the scanner. This is the codes I got back.
C1223 - Fault in ABS Control system
C1246 - Fault in Master Cylender pressure sensor
C1249 - Open circuit in stop light switch circuit
P0504 - Brake Switch A/B correlation
So he did a little research on the P0504 code and read what it said. First step was to leave the vehicle off and push on the breaks to see if the rear breaks will light up. Well my rear break lights did not light up. Well we had to close up shop and went and dropped off my FJ at his house. So went down to the Toyota delearship and bought a new brake light switch. Got back to my friends house and just unplugged the connector from the brake light switch and hooked up the new switch to see if the rear brake lights would come on w/o the vehicle turned on. Well it works. Well I didn't have time to replace the new switch because I needed to drive back to Houston. Well I put about 120 miles with no abs-vsc-trac lights on. Well I got to Houston and check to see if the rear brake lights would come on and they work and I can take it out of park with no problems. I don't have to hit the release button to take it out of park. Well I'm going to take it to another friend in Houston and hook up the scanner again to see if it is still throwing codes. I do have a aftermarket camera system and it plugs to the obII port. I did leave it unhooked on the drive back to Houston to see if the abs-vsc-track lights would come back on. I'm hoping the camara system is not causing the problems, but until the shop opens back up I'll leave it disconnected. Until then.
post #19 of 25 (permalink) Old 08-12-2016, 06:42 PM
Quoted: 0 Post(s)
Well I went to my other friends shop and has him scan again. It is still showing the same errors as previous. So I did change out the brake light switch but didn't have time to go back to my friends shop due to I was called out for work again. I did not hook up the camera system to the OBDII port as of yet. Still don't have the abs-trac-vsc lights. I did leave Houston to go back to Dallas to pack the rest of my cloths to leave to work. While in Dallas I did go get a emissions test and passed. Well in Atlanta, GA now and still no abs-track-vsc lights. I want to run another scan to see if all of the errors have been cleared before I hook the camera back to the OBDII port. The camera system I installed is the Lukas LK-9750. So until then.
post #20 of 25 (permalink) Old 08-18-2017, 11:26 AM
ohiobenz's Avatar
Quoted: 129 Post(s)
Send a message via AIM to ohiobenz Send a message via Yahoo to ohiobenz Send a message via Skype™ to ohiobenz
LRP previously said: View Post
C1223
U0073
U0100
U0123
U0124
U0126
C1223
U0073
U0100
U0123
U0124
U0126
Did you ever resolve this?
My 2008 has all the lights on and, according to the dealer who spent 4.5 hrs last time, my ECM is losing communication with the CAN bus.
My ABS is not active
My airbag system is not active
My VSC and traction control are not active
All per the dealer...
Occasionally the ABS light is off, but comes on after driving a while.
For a period of time the brake light was on, but went off.
Yesterday it came on again.
Ive ordered the brake light switch and will replace it today.
Any suggestions?
'08 Fusion: ARB rack, custom ladder, Jerry-can carrier & Hi-lift mount, DO front bumper, Expedition-1 Rear bumper, DO Hybrid Sliders, MileMarker Hyd Winch, SPEC Stage-1 clutch, Icon Stage 2 3" lift, Cobra CB, PNR Snorkel, Spidertrax spacers, All-Pro Skid plates, Airlift airsprings Plasti-Dipped hood, Arco PIAA fogs, Hella drivin lights & more......
ohiobenz is offline
  Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Transmissions / Transfer Cases / Traction Aids
