Do the Manual FJs have chance of self destruction. - Toyota FJ Cruiser Forum
 12Likes
post #1 of 11 (permalink) Old 09-11-2017, 09:40 PM Thread Starter
Quoted: 2 Post(s)
To preface; I'm searching for my 2nd FJ. My first one kept me absolutely safe in a roll over accident.
SO
In my search I ended up having a conversation with a gentleman that told me to stay FAR FAR away a manual FJ as they are know to self detonate because of an aluminum component. How true is this?
Sean McNeill is offline
post #2 of 11 (permalink) Old 09-11-2017, 09:47 PM
Bar3K's Avatar
Quoted: 1846 Post(s)
Re: Do the Manual FJs have chance of self destruction.
Welcome to the forum
Never heard of a manual transmission FJ grenading
Tell the gentleman to show you the proof.
HERSOG likes this.
Bar3K is offline
post #3 of 11 (permalink) Old 09-11-2017, 10:42 PM
Quoted: 17 Post(s)
my manual has been fine, except for that one time it blew the **** up
Sooth Sayuh likes this.
aelway is offline
post #4 of 11 (permalink) Old 09-11-2017, 10:52 PM
gearwrench's Avatar
Quoted: 479 Post(s)
I believe he was talking about the throw out bearing chirp. There is a repair for it and its not a catastrophic failure by any stretch.
amaclach likes this.
KC3JJX
gearwrench is offline
post #5 of 11 (permalink) Old 09-12-2017, 12:13 AM
Quoted: 1341 Post(s)
The 6-speed manual transmission (RA61F) used in the FJ has a design weakness relating to the support of the clutch throw-out bearing. The bearing slides on an aluminum tube that is an integral part of the front half of the transmission housing.
In some cases the OD of this tube has become severely worn or galled, which in turn triggered problems with the TO bearing. It's not clear why some MT FJs encounter this problem, and others do not.
Correcting the problem entails either:
1. Replacing the transmission housing, which requires a lot of very close-tolerance measurements to get the end play of all the transmission shafts set via selection of the appropriate shims. This might not be a permanent solution, depending on the factors that caused the original wear or galling condition. Because of the level of skill, and the time required to make accurate measurements, many dealers will not replace the transmission housing, but opt to simply replace the entire transmission.
2. Install a thin-walled stainless-steel sleeve over the aluminum tube, providing a hard, smooth surface for the TO bearing to slide on. This fix requires the use of an aftermarket TO bearing with a larger bore that will accept the larger OD of the sleeve.
2010armygreen and amaclach like this.
FJtest is offline
post #6 of 11 (permalink) Old 09-12-2017, 03:30 AM
Desert Moderator
amaclach's Avatar
Quoted: 2854 Post(s)
Sean McNeill previously said: View Post
SO
Not to my knowledge. If there was a weakness in the MT, I would have found it by now, but nothing.
If anything, the MT has a more reliable drivetrain than the AT (FT 4WD, no ADD on the front axle, no need to worry about shifting to 4WD for inclement conditions/road surfaces) at the slight expense of fuel.
There was a squeaky throw out bearing annoyance in some early models, but there's a TSB for that and an aftermarket fix as well if it ever happens.
Good Luck in the search!
Black '14 6MT
Stock bumpers
Some mods
Rear Diff Lock on Demand mod: https://www.fjcruiserforums.com/foru...mand-hack.html
Nannies Off Mod: https://www.fjcruiserforums.com/foru...ml#post1183262
amaclach is online now
post #7 of 11 (permalink) Old 09-12-2017, 08:30 AM
jimmy-buffett's Avatar
Quoted: 899 Post(s)
Bummer that the FJ died, but glad to hear it did its job! If you need any help finding a new FJ, I'd be happy to help you search for one (free / no charge). You might also try reading the buying guide:
https://www.fjcruiserforums.com/forum...j-cruiser.html
Want to see what FOUR years (updated!) of offroading in Colorado looks like? Click Here
Join the Colorado FJ Cruisers Facebook page for Colorado mod days, trail runs and other organized events! Not from Colorado, but planning a trip here? Join up, we'd be happy to suggest some offroading locations for you or even coordinate a run with the locals!
My CB Radio Install+Parts Thread
Complete Guide to Buying and Selling an FJ Cruiser
jimmy-buffett is offline
post #8 of 11 (permalink) Old 09-12-2017, 07:09 PM Thread Starter
Quoted: 2 Post(s)
Thanks y'all. I've always heard really good things about the Blue Room. You're definitely living up to it!!
post #9 of 11 (permalink) Old 09-12-2017, 07:21 PM
mikey's Avatar
Quoted: 1468 Post(s)
11 years with a 6MT.....no issues. Oh sure, the TOB does chirp....but it has been for 10+ years.
Wouldn't trade it for an AT for all the Maple Syrup in Canada.
"It's not easy being Green"
Kermit the Frog
mikey is offline
post #10 of 11 (permalink) Old 09-13-2017, 03:47 PM
chriskrossapplesauce's Avatar
Location: Dayton, OH or Silver Lake, WI or Sugar Grove, IL
Quoted: 622 Post(s)
^^^ 100% agree with @mikey here. Granted I've only owned my 08 for about 2 years and I knew that there was a good chance for a TOB chirp, but I accepted the risk and love it. It seems to only be intermittent at the moment so I'm not too worried about it. MT's are so much more fun anyway
Young, dumb, and blunt - Chris
chriskrossapplesauce is offline
  Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Transmissions / Transfer Cases / Traction Aids
