Another 4WD not working question - please help - Page 2 - Toyota FJ Cruiser Forum
 19Likes
post #11 of 19 (permalink) Old 11-26-2017, 08:36 AM
FJ_Ahoy's Avatar
Quoted: 10 Post(s)
Re: Another 4WD not working question - please help
FJtest previously said: View Post
The switches are easily tested with a digital multimeter. In 2WD range, the switch is OPEN, and the resistance should be multi-megohms. In 4WD range, the switch is CLOSED, and the resistance should be less than 0.5 ohm.
this visual may help along with FJtest comment above,
released = open/2WD
pushed = closed/4WD
debFJVT likes this.
FJ_Ahoy is offline
post #12 of 19 (permalink) Old 11-26-2017, 11:41 AM
Quoted: 1399 Post(s)
Assuming that you have a good quality multimeter that can resolve .10 ohm, and that you can "zero-out" probe resistance, anything more than .5 ohm when the switch is "closed" probably indicates some degradation of the contacts (contamination, tarnish, etc.) within the switch.
On the other end of the scale, 10K ohms when the switch is "open" probably indicates some degradation of the switch seal, with some moisture inside.
FJtest is offline
post #13 of 19 (permalink) Old 11-26-2017, 08:09 PM
FJ_Ahoy's Avatar
Quoted: 10 Post(s)
DEBFJVT, do you have more pictures where you pulled the illumination wiring for it? and it did you create its own ground, or shared a ground with another switch back there?
any input greatly appreciated,
Thank you
FJ_Ahoy is offline
post #14 of 19 (permalink) Old 11-27-2017, 12:34 PM
oldmangarth previously said: View Post
(snip)
- When we say we have a "bad switch" what are we saying? Are we saying there is an electrical component in the switch that is bad but the mechanical part is good? Is this the part that keeps failing? (snip) Thanks.
I have performed failure analysis on several of these transfer case switches, and put together a detailed failure analysis report with photos showing the internal construction of the switches and exactly what failed.
https://www.fjcruiserforums.com/forum...diff-lock.html
The root cause of the failure was the same in all cases: internal contamination of the switch contacts by gear oil. All of these switches have the same design and are subject to the same failure mode.
Make sure that your transmission and transfer case breathers are clear to prevent any buildup of internal pressure that might tend to force gear oil into the switches.
However, I think the actual failure rate is quite low, maybe only a few percent. Test your 4WD, LO RANGE and DIFF LOCK functions regularly (or at least immediately before any challenging off-roading) to make sure that everything works BEFORE you get in a situation where you truly NEED 4WD or a locked rear diff.
FJtest is offline
post #15 of 19 (permalink) Old 11-28-2017, 01:22 AM
MOAB SUPERSTAR
debFJVT's Avatar
Quoted: 2204 Post(s)
FJ_Ahoy previously said: View Post
Thank you
Only have a few pics from the install and not sure if they'll answer your question anout the switch illumination - actulally didn't like the way this particular switch worked so ended up pulling the "bright/on" function so it's the same level whether on or off. Used a screw near the shifter for ground. I can easily pull the switch out and take pics of the back if you need - happy to help!
ID:	964306   Click image for larger version
ID:	964314   Click image for larger version
ID:	964322   Click image for larger version
FJ_Ahoy likes this.
Member of the Month November 2016
TLCA# 25170
debFJVT is online now
post #16 of 19 (permalink) Old 11-29-2017, 01:17 PM
FJ_Ahoy's Avatar
Quoted: 10 Post(s)
Well I did the button hack, used the existing pigtail of transfer case switch, but it still doesn't tell computer to deactivate stability control nor does it get the 4x4 green light going.....Sigh....
I did test the transfer case switch resistance...it read above 1 ohm when closed 4x4 when it should have read below.....
I will be getting another switch and hopefully that will do it....but now I fear, if its not the switch, is it the 4x4 ecu (in glove box ) or the skid control ecu ( under the hood position up from battery )
the plot thickens.
debFJVT likes this.
FJ_Ahoy is offline
post #17 of 19 (permalink) Old 11-29-2017, 01:56 PM
MOAB SUPERSTAR
debFJVT's Avatar
the plot thickens.
You're 100% certain you spliced into switch #3 ? I was worried it was one of my ECUs as well, but happily the new ADD has solved the problem for me. Good luck with the ECU testing - probably easier to do than swap that TC switch from what I understand.
TLCA# 25170
post #18 of 19 (permalink) Old 11-29-2017, 02:12 PM
FJ_Ahoy's Avatar
Quoted: 10 Post(s)
indeed I did, its the single one on the passenger side, easiest one to get to....I replaced it once last year, and here I am a year later getting C1258 again for a failed switch....manual DTC states to check switch and test SKID ECU and 4x4 ECU for specific voltages to confirm they are in spec.
debFJVT likes this.
FJ_Ahoy is offline
post #19 of 19 (permalink) Old 04-25-2018, 06:15 PM
FJ_Ahoy's Avatar
Quoted: 10 Post(s)
Well quick update, it was my Front ADD....all is in working order now....got a new on eBay $185 bucks. 20 bucks in 75-90 oil....and some help from my pops.
FJ_Ahoy is offline
  Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Transmissions / Transfer Cases / Traction Aids
