Did I screw up the easy diff lock on demand hack? - Page 5 - Toyota FJ Cruiser Forum
 35Likes
post #41 of 64 (permalink) Old 01-30-2018, 04:10 PM
ttfjc's Avatar
Quoted: 97 Post(s)
Re: Did I screw up the easy diff lock on demand hack?
ttfjc previously said: View Post
yeah so can anyone confirm that its the white wire with blue stripe to cut on the 2010 + becuase otherwise im stuck. id rather have ABS.
bump
jamesepoop likes this.
2010 FJ Cruiser Trail Teams 6MT
TLCA #24463
Bozeman, MT
https://backcountryadventuretime.wordpress.com
IG:@backcountryadventuretime
ttfjc is offline
post #42 of 64 (permalink) Old 01-30-2018, 04:33 PM Thread Starter
cliffy's Avatar
Quoted: 660 Post(s)
bump
Our Kiwi friend @amaclach has a '14 with the hack. He'll hook you up..
ttfjc likes this.
Dec 2017 member of the month
cliffy is offline
post #43 of 64 (permalink) Old 01-30-2018, 06:13 PM
jamesepoop's Avatar
Quoted: 1143 Post(s)
FatJohnson previously said: View Post
So I turned the nannies off with the inline switch for my no-cut ATRAC/DIFF LOCK HACK and as expected the traction control stopped trying to work. I wonder if this is the result of both hacks being done? So I need to have both mods active for the rear diff lock and have traction control deactivated.
Now I don't know why. Maybe the variation of the mods are so similar yet slightly different, they're causing a cross over. As such, sorry @ttfjc , mine is an '07 as well, but I can say I performed only the diff hack on demand. These are the lights I get (same as yours I believe). ABS does turn off. If you need it on, seems like @FatJohnson did the correct one for you (no-cut hack). My a-trac is not hacked so no test.
First pic is Diff hack on/2wd. Second pic is Diff hack on/4wd.
ID:	991042   Click image for larger version
jamesepoop is online now
post #44 of 64 (permalink) Old 01-30-2018, 08:36 PM
ttfjc's Avatar
Quoted: 97 Post(s)
jamesepoop previously said: View Post
This is what my dash looks like. However, abs is always on when the diff oock is off. So it disabled my abs until i put it back to facrory
TLCA #24463
Bozeman, MT
ttfjc is offline
post #45 of 64 (permalink) Old 01-30-2018, 09:21 PM
FatJohnson's Avatar
Quoted: 880 Post(s)
So from the pics @jamesepoop , the diff hack on it's own when activated, will light all 3 lights vs the single light that I get with both hacks done. Now it makes me wonder who else has done the same hacks as mine on their '07 FJ and what they see on their dash?? Nothing seems consistent other than our diffs all lock up
Sent from my NiPhone using Tapatalk
amaclach likes this.
FatJohnson is offline
post #46 of 64 (permalink) Old 01-31-2018, 02:48 AM
jamesepoop's Avatar
@thane your silver fresco is 2010+ right? You're the one that suggested the diff hack to me. Maybe you have some insight on the ABS issue @ttfjc is having.
post #47 of 64 (permalink) Old 01-31-2018, 02:53 AM
Desert Moderator
amaclach's Avatar
Quoted: 2953 Post(s)
cliffy previously said: View Post
If anybody has any ideas why the diff lock indicator light flashes even though the diff is locked please let me know. I guess it's not a problem since it's engaging but I like things to work as they should.
Hi Cliffy I'm reading through the thread, but at this stage, it looks like you're engaging the diff lock, but the signal wire back to the ECU isn't working for some reason.
The signal wire carries +12v when unlocked and 0v when locked, so perhaps you have earthed the wrong end of the wire? The end that should be earthed is the wire from the plug, not the end coming from the loom.
The speed wire should just be cut.
As a matter of interest, the locker signal wire is the one that you put a switch on when you want to do the no-nannies hack (also in my signature) - all that does is trick the ECU into believing that you are in 4LL with the locker engaged and turns the nannies off (VSC/TRC/ABS).
The Diff lock anytime has the same effect on the VSC/TRC/ABS as the no-nannies hack but it actually locks the diff rather than faking it. Both hacks have their place.
Black '14 6MT
Stock bumpers
Some mods
Rear Diff Lock on Demand mod: https://www.fjcruiserforums.com/foru...mand-hack.html
Nannies Off Mod: https://www.fjcruiserforums.com/foru...ml#post1183262
amaclach is offline
post #48 of 64 (permalink) Old 01-31-2018, 02:56 AM
Desert Moderator
amaclach's Avatar
Ok, I reconnected what I thought was speed sensor wire and no change. The rear diff lock is engaging but indicator light on dash only blinks never stays on 'solid'.
I do believe it to be the speed sensor wire because I have no other obvious symptoms of that wire being cut.
After the nannies instant off mod performed I'm now not getting the vsc and abs lights when diff is locked.... is this normal?
Question for guys with instant off nannies mod. What lights come on your dash when engaged and when you engage diff lock what lights are you getting?
I'll make a video for you and send a link to show normal operation of these mods.
Black '14 6MT
Stock bumpers
Some mods
amaclach is offline
post #49 of 64 (permalink) Old 01-31-2018, 03:10 AM
Desert Moderator
amaclach's Avatar
Disconnecting the terminal resets but it comes back on when i start up after about 5 seconds. I reconnected the wires back to factory and disconnect the terminal and were back to stock no lights everything works. I grounded the wire comming from the little blue box. White wire blue stripe.
The hack worked. But i lose abs.
Didnt touch speedwire
Losing ABS is correct for this hack. Because the rear diff is locked, the car assumes two things:
- You're moving slowly in 4LL
- You know what you're doing and don't want the ECU to take over ANYTHING for you - so no ABS, No VSC, No TRC. ATRAC will still work if you are indeed in 4LL if your model normally allows ATRAC with the rear locker engaged or if you've done the ATRAC+RR DL hack.
Black '14 6MT
Stock bumpers
Some mods
amaclach is offline
post #50 of 64 (permalink) Old 01-31-2018, 04:44 AM Thread Starter
cliffy's Avatar
Quoted: 660 Post(s)
amaclach previously said: View Post
Thanks partner but I think I'm straight with the two mods although with my diff lock on demand hack my indicator light only blinks and never goes solid. The diff is locking though.
I mentioned you because I know you have a '14 with the hack and @ttfjc is having trouble with the hack on his '10. We didn't know if there was a variation of the hack for the newer fj's? Thanks for all your help, much appreciated.
cliffy is offline
  Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Transmissions / Transfer Cases / Traction Aids
