Transmission fluid change? 153,000 miles... - Page 2 - Toyota FJ Cruiser Forum
 2Likes
post #11 of 11 (permalink) Old 03-21-2019, 04:57 AM
rotorhed1's Avatar
Quoted: 1010 Post(s)
Re: Transmission fluid change? 153,000 miles...
My opinion is to drop the pan, check the magnets, replace the filter and install the new gasket with the pan and new fluid. It takes type WS or World Standard. The pan bolts don't get much torque, don't crank them down.
I did mine at around 90k. No problems found. It took several tries to get the level correct. I filled it till fluid came out of the standpipe plug, ran it till it was up to temperature and drove it, going through all of the "gears", adjusted the level. Then did the same a couple of more times before the level was stable.
rotorhed1 is offline
  Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Transmissions / Transfer Cases / Traction Aids
  Similar Threads
New FJ Owner- Tranny Fluid Drain and Fill? fjpkr253 Transmissions / Transfer Cases / Traction Aids 17 11-19-2017 06:53 PM
Transmission Fluid Level check issue KK17 Transmissions / Transfer Cases / Traction Aids 33 01-31-2016 10:12 AM
2014 Fj Cruiser Transmission slipping only 6000 miles pecatus Transmissions / Transfer Cases / Traction Aids 44 09-29-2014 10:52 PM
6 speed how many miles for fluid change? BOSTON4RUNNER General Discussion 17 03-08-2013 10:37 AM
Trans Fluid Life span? NyNomad Transmissions / Transfer Cases / Traction Aids 15 05-17-2012 08:47 AM
