replacing trans cooler lines - Toyota FJ Cruiser Forum
 11Likes
post #1 of 28 (permalink) Old 03-01-2019, 06:31 PM Thread Starter
Quoted: 3 Post(s)
on my 08 with 93,000 miles the trans cooler lines are rusty so I purchased a new set (Rein Automotive TRC0520, replaces #3290760070 ). is there anything I need to know about before I replace this? should I purchase more at fluid? I assume I will lose some during removal? never did this before and I want to get it right. will there be an issue with air in the lines after replacement? any help or advise appreciated.
Glenn Orban is offline
post #2 of 28 (permalink) Old 03-01-2019, 07:52 PM
101Firedog's Avatar
Quoted: 139 Post(s)
Re: replacing trans cooler lines
Glenn Orban previously said: View Post
I don't know anything about the transmission cooler lines specifically, but I always make that assumption when servicing fluid systems. At least have a little bit on hand so if you spill some or drop a hose or something, you have piece of mind that you won't have to run to the store in the middle of your project.
101Firedog is offline
post #3 of 28 (permalink) Old 03-07-2019, 06:39 PM Thread Starter
Quoted: 3 Post(s)
i find it hard to belive that with over two hundred views that no one can comment on this topic that has made this repair??
post #4 of 28 (permalink) Old 05-15-2019, 11:28 PM
DrikaK9's Avatar
Quoted: 2 Post(s)
I'm dealing with same issue. No replies. My 2010 has longer, curved lines, but even posting pictures, I get flamed: dudes pointing out different colored fan shroud, lines are different.... is it even an FJ? What country are you from? I'm trying to find the right lines for mine, and because I know I lost some, I'm just going to do the flush and fill that's written about. Hope you were able to figure out yours!
DrikaK9 is offline
post #5 of 28 (permalink) Old 05-16-2019, 07:37 AM
mikey's Avatar
Quoted: 1413 Post(s)
Its not flaming.
There have been subtle differences in models over the years and by Geographic location and the FJ is a shared platform....hence all the questions.
Just narrowing down the possibilities.
WEB diagnosis is not easy
"It's not easy being Green"
Kermit the Frog
mikey is offline
post #6 of 28 (permalink) Old 05-16-2019, 01:42 PM
DrikaK9's Avatar
Quoted: 2 Post(s)
I stand corrected then. I figured a truck made in Japan would be "fairly" standard outside of model year changes. The part number help has hopefully narrowed it down to a purchase on Ebay. Hopefully folks can see that to an admitted non-expert, the seemingly odd statements about bumpers, fan colors, the oil lines themselves, is it an FJ, sounded just weird! Of course it's an FJ. Add to which, I'm a little jacked up to begin with having the truck out of service to begin with. My apologies, no offence was meant, and the help has been appreciated. Now if I can just figure out if it's the passenger side lower line thats the oil drain line AND this Ebay part fits, life will be better.
DrikaK9 is offline
post #7 of 28 (permalink) Old 05-16-2019, 02:30 PM
mikey's Avatar
No worries, eh?
We do recognize that not everyone is as nerdy about the FJ as others, generally a little patience and some searching and you can find the answer.
Kermit the Frog
mikey is offline
post #8 of 28 (permalink) Old 05-16-2019, 03:07 PM
Boabrother4's Avatar
Quoted: 17 Post(s)
I just did a flush and yes the lower line on the radiator is where you drain from. This was odd to me as all my other trans (non Toyota) I drain from the top.
I went slow, followed the process, 2 quarts at a time until all is clean and red. Top off trans, enjoy.
I did the flush cause my line was rotted as well, I replaced the steel line with rubber hose and 3/8 stainless barb splicers until I can find tube coolers to replace the factory steel line.
So many of the steel trans lines have failed, there has to be a better solution.
2011 Brick
Boabrother4 is offline
post #9 of 28 (permalink) Old 05-16-2019, 05:31 PM
DrikaK9's Avatar
Quoted: 2 Post(s)
Boabrother4 previously said: View Post
does your truck have longer, passenger side curved lines?,, because that's what Im dealing with on mine. Hopefully have a set coming from Ebay. Il post and let you know .. Dealer and local parts store only show a short, Straight set of lines so user the bottom line?
DrikaK9 is offline
post #10 of 28 (permalink) Old 05-16-2019, 05:31 PM
DrikaK9's Avatar
Quoted: 2 Post(s)
Oh and sorry if I came off as a D.
DrikaK9 is offline
  Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Transmissions / Transfer Cases / Traction Aids
  Similar Threads
DIY: OEM FJ Cruiser/Tacoma Oil Cooler Install TinCan Engine Performance 26 03-18-2019 04:08 PM
Temperature rating of Trans. cooler hoses? razcob Transmissions / Transfer Cases / Traction Aids 6 06-17-2018 05:14 PM
what BTU rating for trans cooler needed? 51062 Transmissions / Transfer Cases / Traction Aids 130 07-07-2016 05:10 PM
How much PSI is in the transmission lines to the cooler? albybaby Transmissions / Transfer Cases / Traction Aids 3 09-01-2012 08:33 AM
Auto Trans Oil Cooler PKTrailRider Misc. Technical Discussion 5 02-07-2009 04:05 AM
