Broken Ring Gear Teeth - Page 4 - Toyota FJ Cruiser Forum
 54Likes
post #31 of 43 (permalink) Old 03-24-2019, 10:39 AM
jamesepoop's Avatar
Quoted: 1088 Post(s)
Re: Broken Ring Gear Teeth
Thanks for sharing @norm356 I always enjoy your informative insight. There's more research and testing with cryo. Very little in what I posted from that 4wheel link. I was just trying to find an easy article to share the info. There's a couple methods for achieving the metallurgy treatment so it's best to consult a shop on the most appropriate method. Just like when you have mechanical parts built, it's best to go with the instructions/ shop's recommendation. The internet does not always have the answer
jamesepoop is offline
post #32 of 43 (permalink) Old 03-24-2019, 11:46 AM
Forum Beer Miester
Thorn661's Avatar
Quoted: 2030 Post(s)
There were issues with some Nitro gear sets around that time frame if memory serves, I think it was concerning the hardening of the ring gear, I can’t remember where I read it but I’ll do a search on Mud to see what I find.
On another note when I bought my 4.88’s from ECGS I asked why not recommend a high end synthetic? Their reply was that they had seen failures stemming from high temps that had caused several different types of failures and the Lucas did a far better job of curtailing these temperature related failures and wouldn’t break down under the extreme stress as the synthetics would.
I lean towards this being either a design failure or simply a bad heat treat myself perhaps exacerbated and exposed by extreme heat cylcling. I may be all wet on this hypothesis but that’s where I gotta put my money.
jamesepoop and Firemedic831 like this.
Thorn661 is offline
post #33 of 43 (permalink) Old 03-24-2019, 12:59 PM
Forum Beer Miester
Thorn661's Avatar
Ok I’ve been searching and I can’t find any thread with that info yet.
I would be curious if this set predated the manufacturing of nitro’s ‘thick ring gear’ sets for the 8.2? Maybe a comparison of the serial numbers with latter sets with the thicker design could yield a clue.
debFJVT likes this.
Thorn661 is offline
post #34 of 43 (permalink) Old 03-28-2019, 07:49 PM
stephous's Avatar
Quoted: 12 Post(s)
You might also call J&S Gear Co for advice. They are in Huntington Beach and helped me resolve many of my drive line problems (714) 841-4545.
Pepe Le Pew: Allterrain Model, Wrangler Ultraterrains, Magnaflow, Bilstein 5100s, Pre-cleaner, FJ off road lights, optional 16" wheels
stephous is offline
post #35 of 43 (permalink) Old 03-28-2019, 09:24 PM
Cruiser47's Avatar
Quoted: 43 Post(s)
[quote=Thorn661;9200918]There were issues with some Nitro gear sets around that time frame if memory serves, I think it was concerning the hardening of the ring gear, I canít remember where I read it but Iíll do a search on Mud to see what I find.
On another note when I bought my 4.88ís from ECGS I asked why not recommend a high end synthetic? Their reply was that they had seen failures stemming from high temps that had caused several different types of failures and the Lucas did a far better job of curtailing these temperature related failures and wouldnít break down under the extreme stress as the synthetics would.
I lean towards this being either a design failure or simply a bad heat treat myself perhaps exasperated and exposed by extreme heat cylcling. I may be all wet on this hypothesis but thatís where I gotta put my money.
Cruiser47 is offline
post #36 of 43 (permalink) Old 03-28-2019, 09:53 PM
Quoted: 1325 Post(s)
Regarding ring gear fracture, tooth failure (both via instantaneous overload and high-cycle fatigue) can be influenced by the accuracy of the initial gear contact pattern, or by changes in the contact pattern due to loss of bearing preload.
Setting up a new third member to get the correct gear tooth contact pattern with new gears, new bearings, and new crush sleeve is very much an art, and needs to be done by someone who has the correct tools and really understands what they are doing. Proper preload in both the pinion and carrier bearings is necessary to maintain the correct tooth contact pattern as everything "wears in". Properly setup, properly broken in, and properly lubricated, an accurately ground and properly heat-treated ring and pinion set can continue to function silently for 300K+ miles. Done wrong, and it can start to whine in 20K miles or less.
FJtest is offline
post #37 of 43 (permalink) Old 03-28-2019, 11:10 PM
HERSOG's Avatar
Quoted: 363 Post(s)
After I received the Dana 60 from ESGS, Chaseís shop, he also emailed the flowing charts for gear oil change intervals.
I have also installed a digital temp gauge to monitor the oil temperature.
Here is a copy/pasted the email from Chase.
Dennis, flow the chart and monitor the oil temp on your D60 and use 85w140 Lucas oil
4 Most Important Attributes to Gear Oil
Cling Ratio
Water separation properties
Cushioning Factor
Temperature Control
Temp Reference Chart Ė oil change frequency
170 Deg - 100,000 Miles
200 Deg - 50,000 Miles
220 Deg - 25,000 Miles
240 Deg - 12,000 Miles
260 Deg - 5,000 Miles
260-300 Deg Ė 500-1000 Miles until Temp is controlled
Differential Temp Guide
250-275 Degrees is Normal for new differentials breaking in, do not Tow or take long road trips for first 500 miles as this builds additional heat. 300 degrees is to hot and diff should be allowed to cool.
Normal operating Temp for a differential adequate for vehicle in stock applications 170-220 degrees
Normal operating Temp - Large tires, Undersized Differentials, Towing 200-250 Degrees.
Final Notes
Change your oil frequently your diff will thank you
If water is ever introduced to differential change it immediately, keep in mind that a differential that is hot and then becomes cool will naturally draw in moisture, so it is not always a water crossing that causes moisture contamination, always run a vent to a dry area and insure it breathes easily.
[email protected]
debFJVT, Thorn661, Lee44 and 2 others like this.
ďThere is no hunting like the hunting of man, and those who have hunted armed men long enough and liked it, never care for anything else thereafter.Ē
2010 TT 6MT. 4.56+ARB locker, Icon Coil Over Shocks+FOX 2.5 Rear+Icon UCA. All pro HD steering Kit. Metal Tech tube bumper with Caterpillar GTB 9000 Winch. Light Force Striker 170 HID. K&N cooled Air Intake. Ricochet Skid Plate. All-Pro Rear LCA. ARB Half Rack. Boztech Diff skid 285/75/16 Goodyear MTR, Edelbrock Exhaust. URD Short Shifter. Total Chaos LCA Skids.
And Death Valley Is The Place To Be
HERSOG is offline
post #38 of 43 (permalink) Old 03-29-2019, 07:43 AM
Forum Beer Miester
Thorn661's Avatar
HERSOG previously said: View Post
Cling Ratio
Cushioning Factor
Temperature Control
Final Notes
[email protected]
Thatís some really great info, love that temperature gauge mod.
@Cruiser47 did your post quote get screwed up? I donít see a response from you, anyway thanks it made me notice my phone autocorrected exacerbated to exasperated.
HERSOG likes this.
Thorn661 is offline
post #39 of 43 (permalink) Old 03-29-2019, 09:33 AM
トヨダ Master
CabinCruiser's Avatar
Quoted: 3283 Post(s)
Thorn661 previously said: View Post
I lean towards this being either a design failure or simply a bad heat treat myself perhaps exacerbated and exposed by extreme heat cylcling. I may be all wet on this hypothesis but thatís where I gotta put my money.
I remember talking to you about this prior to your gear swap. Some of the earlier Nitro sets were improperly heat treated and led to some major failures. We've seen as many as 6 sets that I can remember that failed within the 1st 20k miles. ECGS does require the use of Lucas 85w-140 non-synthetic oil which works well with their tight tolerance setups. They also will build units without new bearings. A lot of shops do this, although I don't know why. Saving $$ now usually means paying for it on the back end so just do it right the 1st time. I'm suspecting that in this case improper setup, or improper heat treating to the gears, or break in, etc.
Something that a lot of customers don't understand also is that it is very hard to break in a front R&P in a 4 wheel drive. The rear will take the load of the whole vehicle in 2wd, but only half in 4wd. Something that I try to do is break in the rear first and then remove the rear driveshaft and run in only FWD for 500 miles while breaking in the front. This way when pulling the rear around on the coast side of the gear, the rear is already broke in, and the R&Ps break in with the full weight of the vehicle on them. This isn't practical for most people but it is the best way if possible.
HERSOG, Thorn661 and jamesepoop like this.
"Silence is Golden......Duct Tape is Silver"
Solitude Allows One to Reflect While Others are Reacting...
Member of the month-October 2017
CabinCruiser is offline
post #40 of 43 (permalink) Old 03-29-2019, 10:00 AM
jamesepoop's Avatar
Great info so far!
  Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Transmissions / Transfer Cases / Traction Aids
  Similar Threads
Bought a regeard FJ and now screwed LTipton Transmissions / Transfer Cases / Traction Aids 78 03-03-2017 05:38 PM
WTB - MT6 Transmission (not t-case) bandi Want to Buy (FJ Related Items) 19 08-19-2013 09:32 PM
replace stock 4Lo for Marlin Crawler gear MAD MARK Transmissions / Transfer Cases / Traction Aids 87 12-13-2012 05:36 PM
2010 Lone Star Toyota Jamboree January 15-17, 2010 WILSON Texas 943 01-23-2010 11:50 PM
Cracked ring gear..... Rubicon Problems / Dealer Service 11 02-13-2007 11:39 PM
