Transmission oil cooler hose protection - Page 2 - Toyota FJ Cruiser Forum
 16Likes
post #11 of 22 (permalink) Old 05-19-2019, 07:15 PM Thread Starter
ArupFJ's Avatar
Quoted: 24 Post(s)
Re: Transmission oil cooler hose protection
Firemedic831 previously said: View Post
i have no idea . I have a power steering cooler also . They were out of the Gauges when i installed mine . But i think i am just going to change the Stereo to one were i can see the coolant temps also
Or get a OBD scanner and Torque Pro and monitor both TCT and TFT. On my vehicle the temp drop with the Hayden 679 is steady 30F and temps never hit over 180 no matter what the driving conditions maybe.
ArupFJ is offline
post #12 of 22 (permalink) Old 05-19-2019, 07:33 PM
Iconic_'s Avatar
Quoted: 2514 Post(s)
You can, I've also edge trimmed any sharp corner the hoses pass near.
https://www.ebay.com/itm/120-Car-Doo...e2eeaad0e8ccf0
Lee44, jamesepoop, ArupFJ and 1 others like this.
Iconic_ is offline
post #13 of 22 (permalink) Old 05-19-2019, 09:46 PM
Bad Wolf's Avatar
Quoted: 315 Post(s)
101Firedog previously said: View Post
I put almost every cable, wire, and hose inside one of those. Order online from a made-in-USA, high-heat-rated one if you're going for engine compartment; off-the-shelf or discount Chinese works for sheathing wires inside the vehicle.
Can you post a couple engine bay pics ?
Bad Wolf is offline
post #14 of 22 (permalink) Old 05-20-2019, 01:02 AM
jamesepoop's Avatar
Quoted: 1090 Post(s)
Lol that plastic isn't stopping anything. The ribbing is already easy to slice... Rubbing on metal, the vibrations will merely make quick work. Along with what @Iconic_ posted some type of anti heat or fire sleeve is what we use on track cars to keep the parts happy from unwanted contact.
jamesepoop is online now
post #15 of 22 (permalink) Old 05-20-2019, 02:17 AM Thread Starter
ArupFJ's Avatar
Quoted: 24 Post(s)
I made sure that no sharp edges are rubbing the hoses and wherever there is a chance I have double duct taped.
jamesepoop likes this.
ArupFJ is offline
post #16 of 22 (permalink) Old 05-20-2019, 03:10 AM
jamesepoop's Avatar
@ArupFJ you should be fine. Fuel and oil rated lines are usually reinforced casing. Give a transmission hose a slice with a razor blade. It does take some force to get those hose to give up. I guess heat may play it's role too in regards to softening the rubber. You may also consider replacing oil cooler kit clamps that tear and loosen due to expanding and contracting rubber.
I'd suggest good clamps such as OE spring clamps or smooth band worm gear clamps that won't damage the rubber
ArupFJ likes this.
post #17 of 22 (permalink) Old 05-20-2019, 04:16 AM Thread Starter
ArupFJ's Avatar
Quoted: 24 Post(s)
jamesepoop previously said: View Post
I replaced the standard clamps that came with the Hayden with this https://precisionbrand.com/products/...er-pack-of-10/
ArupFJ is offline
post #18 of 22 (permalink) Old 05-20-2019, 06:03 AM
jamesepoop's Avatar
@ArupFJ you went with these?
I'd recommend the smooth body clamps. Both will work
Iconic_ previously said:
LEDLIYFJL: Live Every Day Like Its Your FJ's Last
Mad Maxxine Build - 2007 Fresco Silver Metallic
My Travels: http://www.downtownfotos.com
post #19 of 22 (permalink) Old 05-20-2019, 01:56 PM Thread Starter
ArupFJ's Avatar
Quoted: 24 Post(s)
jamesepoop, yes I went with the ones on top but the ones you posted have far less jaggies to cut into the rubber. However the precision clamps are far better built and smoother inside than the ones that came with Hayden and are built out of stainless steel and thats a plus. Next time will use your recommendation.
ArupFJ is offline
post #20 of 22 (permalink) Old 05-23-2019, 07:07 PM
101Firedog's Avatar
Quoted: 142 Post(s)
Bad Wolf previously said: View Post
Here are some closeups of the densest areas of loomed hoses & wires. One of 'em's interior (for the rear battery/fridge), and one of 'em's exterior (brake line over the rock slider mounts), but the rest are engine bay.
Can you spot the 2 that I still need to get around to? There're 2 more like that elsewhere in the car.
Name:	Front of Battery Rat's Nest.jpg
ID:	1080398   Click image for larger version
Name:	Starter and Alternator and Fuse Box.jpg
ID:	1080400   Click image for larger version
Name:	PCV Catch Can.jpg
ID:	1080402   Click image for larger version
Name:	Supercharger Coolant and Sensor.jpg
ID:	1080404   Click image for larger version
Name:	Front Aux Lights.jpg
Name:	Brake Line Over Sliders.jpg
ID:	1080410   Click image for larger version
Name:	Fridge Looms.jpg
Bad Wolf likes this.
101Firedog is offline
  Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Transmissions / Transfer Cases / Traction Aids
  Similar Threads
Wrong Oil krelubot Misc. Technical Discussion 17 12-12-2015 12:44 AM
Tranny Cooler + Fan Installation Sand Crawler Transmissions / Transfer Cases / Traction Aids 12 05-09-2015 03:21 AM
Inchworm "Lefty" Transfer Case Install 1911 Transmissions / Transfer Cases / Traction Aids 28 03-29-2015 11:16 PM
Oil Cooler soderquist Misc. Technical Discussion 6 10-25-2009 05:25 PM
Inchworm Lefty T-Case 1911 How-To Technical Articles 4 11-30-2008 09:03 AM
