Transmission oil cooler hose protection - Toyota FJ Cruiser Forum
 16Likes
post #1 of 22 (permalink) Old 05-18-2019, 08:26 PM Thread Starter
ArupFJ's Avatar
Quoted: 23 Post(s)
Anyone used PVC sheaths for protecting the transmission cooler hoses? The one they use for electrical wires and hoses.
ArupFJ is offline
post #2 of 22 (permalink) Old 05-19-2019, 06:18 AM
Quoted: 3 Post(s)
Re: Transmission oil cooler hose protection
That's not going to provide much in the way of protection.
Elwood P Dowd is offline
post #3 of 22 (permalink) Old 05-19-2019, 02:38 PM Thread Starter
ArupFJ's Avatar
Quoted: 23 Post(s)
Elwood P Dowd previously said: View Post
True but it will give some protection from stray hits and joints before the pipes get ruptured.
ArupFJ is offline
post #4 of 22 (permalink) Old 05-19-2019, 05:01 PM
Sanderhawk's Avatar
Quoted: 928 Post(s)
I would wonder if that would hold moisture and make the line rust?
Elwood P Dowd likes this.
Steve.... 07 FJ with almost enough mods.... August 2017 Member of the month
Sanderhawk is offline
post #5 of 22 (permalink) Old 05-19-2019, 05:02 PM
101Firedog's Avatar
Quoted: 139 Post(s)
I put almost every cable, wire, and hose inside one of those. Order online from a made-in-USA, high-heat-rated one if you're going for engine compartment; off-the-shelf or discount Chinese works for sheathing wires inside the vehicle.
101Firedog is offline
post #6 of 22 (permalink) Old 05-19-2019, 05:23 PM
Firemedic831's Avatar
Quoted: 443 Post(s)
My Trans Cooler Lines Came with that on them .
ArupFJ likes this.
09 AT Toytec Boss performance 3inch lift, Demello sliders , TRD brakes , MT offset Lower links . Rad Rubber splash guards ,Cobra CB,
Firemedic831 is online now
post #7 of 22 (permalink) Old 05-19-2019, 05:26 PM
Quoted: 443 Post(s)
Here is a pic
ArupFJ likes this.
post #8 of 22 (permalink) Old 05-19-2019, 05:53 PM Thread Starter
ArupFJ's Avatar
Quoted: 23 Post(s)
Firemedic831 previously said: View Post
Here is a pic
Exactly the reason I am putting them on mine, I know the Wholesale kit comes with them. I am also tying down the hose wherever needed as I don't want them to touch other parts and get damaged.
Firemedic831 likes this.
ArupFJ is offline
post #9 of 22 (permalink) Old 05-19-2019, 05:56 PM Thread Starter
ArupFJ's Avatar
Quoted: 23 Post(s)
How much drop in temps did you get after installing the cooler btw?
ArupFJ is offline
post #10 of 22 (permalink) Old 05-19-2019, 06:07 PM
Quoted: 443 Post(s)
i have no idea . I have a power steering cooler also . They were out of the Gauges when i installed mine . But i think i am just going to change the Stereo to one were i can see the coolant temps also
  Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Transmissions / Transfer Cases / Traction Aids
  Similar Threads
Wrong Oil krelubot Misc. Technical Discussion 17 12-12-2015 12:44 AM
Tranny Cooler + Fan Installation Sand Crawler Transmissions / Transfer Cases / Traction Aids 12 05-09-2015 03:21 AM
Inchworm "Lefty" Transfer Case Install 1911 Transmissions / Transfer Cases / Traction Aids 28 03-29-2015 11:16 PM
Oil Cooler soderquist Misc. Technical Discussion 6 10-25-2009 05:25 PM
Inchworm Lefty T-Case 1911 How-To Technical Articles 4 11-30-2008 09:03 AM
