8.2" lsd - Page 2 - Toyota FJ Cruiser Forum
 12Likes
post #11 of 29 (permalink) Old 05-28-2019, 01:29 PM
トヨダ Master
CabinCruiser's Avatar
Quoted: 3287 Post(s)
Re: 8.2" lsd
Limited Slip for 2014 Toyota FJ Cruiser
Personally, I'd just use A-Trac and keep the factory E-Locker for those "unneeded" scenarios. I mean it's already paid for.
"Silence is Golden......Duct Tape is Silver"
Solitude Allows One to Reflect While Others are Reacting...
Member of the month-October 2017
CabinCruiser is offline
post #12 of 29 (permalink) Old 05-28-2019, 10:31 PM Thread Starter
Quoted: 4 Post(s)
Re: 8.2" lsd
ZerosFJ previously said: View Post
just out of curiosity why do you want to swap to an LSD?
because i like to play and drift in sand dunes in 2hi, i don't go to rocks at all
and also better traction on road
Nawaf Alkridess is offline
post #13 of 29 (permalink) Old 05-28-2019, 10:32 PM Thread Starter
Quoted: 4 Post(s)
Re: 8.2" lsd
CabinCruiser previously said: View Post
thanks but the link is just for 8" diff, i have the new one 8.2"
i like to use it in 2hi the diff lock and A-Trac is just on 4lo
post #14 of 29 (permalink) Old 05-28-2019, 10:55 PM
bazross's Avatar
Quoted: 1775 Post(s)
Re: 8.2" lsd
G'Day,
If you like to drift...... you need this
https://www.fjcruiserforums.com/foru...ecu-flash.html
cheers
Baz
bazross is online now
post #15 of 29 (permalink) Old 05-29-2019, 01:25 AM
Mean Time Moderator
ZerosFJ's Avatar
Quoted: 1384 Post(s)
Re: 8.2" lsd
Nawaf Alkridess previously said: View Post
There is an easy to do hack to be able to use these in 2wd/high range. @amaclach will chime in the links are in his signature.
amaclach likes this.
2014- FJC Cement "Eddystone" US spec personal import - mods in progress https://www.fjcruiserforums.com/foru...eddystone.html
ZerosFJ is offline
post #16 of 29 (permalink) Old 05-29-2019, 05:55 AM
Desert Moderator
amaclach's Avatar
Quoted: 2823 Post(s)
Re: 8.2" lsd
Yep. Just do it.
See the Diff Lock Anytime link in my sig below. It's pretty easy.
It also turns TRC/VSC/ABS off while the diff is locked.
Black '14 6MT
Stock bumpers
Some mods
Rear Diff Lock on Demand mod: https://www.fjcruiserforums.com/foru...mand-hack.html
Nannies Off Mod: https://www.fjcruiserforums.com/foru...ml#post1183262
amaclach is offline
post #17 of 29 (permalink) Old 05-29-2019, 06:12 AM
トヨダ Master
Re: 8.2" lsd
If you punch in the vehicle perameters, this is what comes up. Seems like I remember that only the ring gear is larger on the carrier and it will work. Give Auburn Gear a call and find out.. All they can say is No and try to fix their catalog error.
post #18 of 29 (permalink) Old 05-29-2019, 06:14 AM
トヨダ Master
Re: 8.2" lsd
But again, I did the gray wire hack, so I have rear locker anytime, on command. Works great in sand, snow, loose gravel, etc.
post #19 of 29 (permalink) Old 05-29-2019, 06:21 AM
Desert Moderator
amaclach's Avatar
Re: 8.2" lsd
Don't switch to the 8.0 - it's not as strong, and the axle tubes are reinforced on your GCC spec 8.2.
The US Spec axle tubes on the 8.2 are not reinforced.
Just follow the Diff Lock on demand link in my signature and do donuts & drift to your heart's content in 2H & 4H.
I did a monster donut & drift combo yesterday because I saw a nice patch of sand that needed to be shredded
CabinCruiser likes this.
Black '14 6MT
Stock bumpers
Some mods
amaclach is offline
post #20 of 29 (permalink) Old 05-29-2019, 11:04 PM Thread Starter
Quoted: 4 Post(s)
Re: 8.2" lsd
G'Day,
cheers
Baz
yeah but the problem is in the open diff
  Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Transmissions / Transfer Cases / Traction Aids
  Similar Threads
Making sense of TRAC, Auto LSD, ATRAC, VSC, & Rear Diff lock. Tranman Transmissions / Transfer Cases / Traction Aids 165 08-09-2016 08:29 PM
Lsd??? gomez_ea2 Transmissions / Transfer Cases / Traction Aids 18 11-25-2015 08:45 AM
2007+ Tundra Auburn Gears LSD BNIB $300 Shipped! ajfj33 Non FJ classifieds 2 08-06-2015 08:14 PM
auto LSD - on 4WD... Frank_B Misc. Technical Discussion 28 06-21-2015 05:52 AM
do i need lsd additive viking1 Newbie Discussions 8 01-02-2008 07:28 PM
