Upgrade Rear Drive Shaft or carry spare? - Toyota FJ Cruiser Forum
 26Likes
post #1 of 17 (permalink) Old 08-22-2019, 11:17 AM Thread Starter
Quoted: 104 Post(s)
For some background, I'm heading to Moab in two weeks for a week of hitting the best trails (Fins n Things, Hellís Revenge, Top of the World, Elephant Hill, Poison Spider/Golden Spike/ Gold Bar Rim, Steel Bender, etc.).
I'm getting my FJ ready and have started to pile up my "spare parts", such as CV axle, inner/outer tie rods, fluids, etc. and it got me thinking, what about the rear drive shaft?
I have a full set of RCI steel skids, but the drive shaft is exposed. One hit from a rock could put it out (obviously I won't be aiming to hit a rock with my drive shaft). This leads me to question whether I should:
A) Upgrade the rear drive shaft before going
B) Carry a spare OEM drive shaft
C) Say F it and not worry about it
I called around and found a local driveline shop that said they'd build me a custom 3" drive shaft with reinforced tubing for $375 (that's balanced, too). I can get the OEM for this price as well. Unsure of how to go on this, just don't want to be left with FWD only on the trails, especially since I'm the only Toyota in a group of Jeep's that are all built and on 35's/37's.
jamesepoop likes this.
DucRider is offline
post #2 of 17 (permalink) Old 08-22-2019, 11:41 AM
Firemedic831's Avatar
Quoted: 526 Post(s)
Re: Upgrade Rear Drive Shaft or carry spare?
F it and not worry about it . but if you are just pick up a used oem .
debFJVT likes this.
09 AT Toytec Boss performance 3inch lift, Demello sliders , TRD brakes , MT offset Lower links . Rad Rubber splash guards ,Cobra CB,
Firemedic831 is online now
post #3 of 17 (permalink) Old 08-22-2019, 11:46 AM
Serenity Now's Avatar
Quoted: 423 Post(s)
I'd worry more about busting a front CV axle than the rear driveshaft. I've been wheeling for 18+ years and never had to replace the driveshaft.
Winterpeg likes this.
Steve in MN, sponsored by Blue Sun Corporation
2010 FJ, now with exciting grill and shifter knob mods
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." - Jeremy Clarkson
Serenity Now is offline
post #4 of 17 (permalink) Old 08-22-2019, 12:00 PM
Quoted: 139 Post(s)
Done all your trails 3 or 4 times each and others in CA more difficult. I have only broken inner tie rods and front shafts. Rear shaft is almost bulletproof. Donít think you have all the tools and lube to change the front shaft, know you do. Same with tie rods do you have what it takes to take one out of R&P?
Sparky of SoCal is offline
post #5 of 17 (permalink) Old 08-22-2019, 12:29 PM
mikey's Avatar
Quoted: 1486 Post(s)
Don't go looking for a can of worms......
Bar3K likes this.
"It's not easy being Green"
Kermit the Frog
mikey is offline
post #6 of 17 (permalink) Old 08-22-2019, 12:39 PM Thread Starter
Quoted: 104 Post(s)
Firemedic831 previously said: View Post
Used are ~$250 from what I’ve found
Serenity Now previously said: View Post
Great data point
Sparky of SoCal previously said: View Post
Done all your trails 3 or 4 times each and others in CA more difficult. I have only broken inner tie rods and front shafts. Rear shaft is almost bulletproof. Don’t think you have all the tools and lube to change the front shaft, know you do. Same with tie rods do you have what it takes to take one out of R&P?
Good to know, I’ve got new CV’s, inner/outer tie rods, and the associated tools (hub puller, 35mm socket, torque wrenches, tie rod wrench, joint separator, etc.) 2 qts of diff fluid, and grease gun full of superlube. Anything else I’m missing?
Thanks for the reality check. It’s easy to get carried away with prepping for this
bazross likes this.
DucRider is offline
post #7 of 17 (permalink) Old 08-22-2019, 01:58 PM
Quoted: 526 Post(s)
Maybe a dumb question But do you know how to change the CV ? Have you changed 1 before ?. Sometimes they can be fun to get out .
Sparky of SoCal and DucRider like this.
post #8 of 17 (permalink) Old 08-22-2019, 02:09 PM Thread Starter
Quoted: 104 Post(s)
Good question, and yes I do. I just replaced the spindles with a gusseted total chaos spindle. This involved pulling the hub and disconnecting it from the UCA/LCA. Plus I have a full downloaded pdf version of the FSM.
Firemedic831 likes this.
DucRider is offline
post #9 of 17 (permalink) Old 08-22-2019, 02:39 PM
TexasFJ's Avatar
Quoted: 84 Post(s)
OH! I love that song!!
debFJVT likes this.
What doesn't kill me makes me more cynical.
TLCA #26213
TexasFJ is offline
post #10 of 17 (permalink) Old 08-22-2019, 03:25 PM
MOAB SUPERSTAR
debFJVT's Avatar
Quoted: 2135 Post(s)
I have a spare driveshaft and decided not to bring it to Moab. I’ve done all those trails (and more) multiple times and never saw a direct hit to it, or saw anyone else break theirs. Sounds like you’re well peprepared and agree you probably won’t need a spare driveshaft. Have a great time and show those Heeps how Toyota rock
Member of the Month November 2016
TLCA# 25170
debFJVT is online now
  Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Transmissions / Transfer Cases / Traction Aids
