Alignment check and spacer ??? - Toyota FJ Cruiser Forum
Forum sponsored by: Discount Tire
 3Likes
  • 1 Post By mikey
  • 1 Post By mikey
  • 1 Post By Boabrother4
post #1 of 6 (permalink) Old 05-15-2019, 04:21 PM Thread Starter
Boabrother4's Avatar
Quoted: 11 Post(s)
Hey, been working on Da Brick, lifting and such and got around to getting new tires, 285/75/17. I am getting some rubbing on the UCA's (JBA high caster) at full lock and will need a spacer to fix this. Are you FJers running spacers on the front only or front and back for equal width? Plan to get Spidertrax 1.25" spacers, Any reason to get a wider spacer? should I get 2 or 4?
The wheel alignment specs show I'm just out of spec on caster for the front right wheel. Tire shop guy said I'm good to go and wont see odd tread ware due to this. He also said I would need aftermarket cam bolts to get the caster correct. Does this sound correct to you guys?
2011 Brick
Boabrother4 is offline
post #2 of 6 (permalink) Old 05-15-2019, 04:58 PM
mikey's Avatar
Quoted: 1381 Post(s)
Re: Alignment check and spacer ???
Boabrother4 previously said: View Post
Ö.
No. How is one side in spec and the other not?
Boabrother4 likes this.
"It's not easy being Green"
Kermit the Frog
mikey is offline
post #3 of 6 (permalink) Old 05-15-2019, 05:06 PM Thread Starter
Quoted: 11 Post(s)
I'll call the tire shop in the morning and get clarification.
2011 Brick
post #4 of 6 (permalink) Old 05-16-2019, 10:48 AM Thread Starter
Quoted: 11 Post(s)
Alright, the FJ is back at the tire shop, after some whining about frozen cam bolts they are working on fixing the alignment.
Told them they should have been up front about this as we could work together to solve problems.
Hoping it's done right this time.
2011 Brick
post #5 of 6 (permalink) Old 05-16-2019, 10:59 AM
mikey's Avatar
Good to hear
Kermit the Frog
mikey is offline
post #6 of 6 (permalink) Old 05-16-2019, 01:54 PM Thread Starter
Quoted: 11 Post(s)
2nd times a charm, Said they struggled with the cam bolts but got them to move.
Feeling much better now that all is within spec considering the tires are new.
FJFool likes this.
2011 Brick
  Similar Threads
Please Check My Alignment Specs!!!!! Boydo Suspension / Steering Tech 12 04-24-2015 09:02 AM
Tire + Spacer Sanity Check JimmyTheDriver Wheels and Tires 1 10-20-2014 10:40 AM
Briareos's Build Briareos Member Build Ups 106 09-27-2014 07:13 AM
Afe cai and silver bullet afe throttle spacer for fj, tundra or tacoma CzechRacingTeam Want to Sell (FJ Related Items) 10 11-12-2013 08:19 AM
Coil Over vs Spacer Lift Kits "Cliff Notes" kfrosty 4x4 / Off-Road Tech 3 05-18-2006 10:45 AM
