Wheel Backspacing for 35s - Page 2 - Toyota FJ Cruiser Forum
Forum sponsored by: Discount Tire
post #11 of 20 (permalink) Old 11-02-2009, 04:12 PM
Quoted: 0 Post(s)
Re: Wheel Backspacing for 35s
I know its from June, but bump...i wanna hear this too. pro comp 3.75? or wheelers. Did u get the wheels yet?
amojohnny is offline
post #12 of 20 (permalink) Old 11-03-2009, 06:42 PM Thread Starter
5Greens's Avatar
Quoted: 2 Post(s)
I got the 16" pro comp rock crawler (87-6883t) 16x8-3 3/4 backset mounted with BFG KM2 315/75R16. The truck has a 3" OME lift and a Demello bumper. I put 2" spacers under the rear bump stops. I have the slightest rub at extreme flex inside rear wheel wells. I am verry pleased with the out come. Will post pictures tomorrow.
2007 -VOODOO 4x4 AT, CQ, GY, RB, UR, 5A, Z2, C7, LOJACK
Mods Listed at AFJ4x4.COM
5Greens is offline
post #13 of 20 (permalink) Old 11-03-2009, 06:54 PM Thread Starter
5Greens's Avatar
Quoted: 2 Post(s)
Found a couple pictures to post tonight. More to follow.
5Greens is offline
post #14 of 20 (permalink) Old 11-04-2009, 12:12 PM
Quoted: 0 Post(s)
5Greens previously said: View Post
sweeeeet. Thats exactly my setup. Nice. Now I just need the wheels and tires. Ive got the demello as well with a winch. That setup is damn heavy though. Im starting to think that the 885's are too light, and might move up to the 886. By 3" OME, is that what you meant? Any spacers up front?
Love the set up man. Time to buy me some new wheels and tires.
Thanks
post #15 of 20 (permalink) Old 11-04-2009, 01:47 PM
VT_RainMan's Avatar
Quoted: 0 Post(s)
Do you think 4" would clear the UCA's? In other words, do you have more than a 1/4" between your inner tire and the UCA's?
I want to get wheels in the near future... with the hopes of being able to go to 35's in a year or so. Just trying to get the right wheels now. The wheeler's with the 4" backspacing seems like a good deal.
2007 FJ 6MT black -n- black
VT_RainMan is offline
post #16 of 20 (permalink) Old 11-04-2009, 05:36 PM
lomuchacho's Avatar
Quoted: 0 Post(s)
Backspacing:
Also called rear spacing. Distance from extreme back edge of
rim, not bead seat, to the mounting pad. Lay a straight edge
across back edge of rim and measure down to mounting pad.
Wheel Offset
The distance from the wheels centerline to the plane at which
the wheel meets the hub. Positive offset is toward the outside
of the rim, negative offset is toward the inside. Zero offset is
the center of the rim.
IF IT DOSENīT RUB, YOU NEED BIGGER TIRES
Visit us at facebook
http://www.facebook.com/media/set/?s...07116346028818
lomuchacho is offline
post #17 of 20 (permalink) Old 11-05-2009, 08:21 AM
VT_RainMan's Avatar
Quoted: 0 Post(s)
lomuchacho previously said: View Post
Backspacing:
Wheel Offset
I'm not sure if you were directing this to me or not? Thanks for the lesson though. I kinda knew that... not that I ever get it right. I know if I have less backspacing the wheel will be pushed out further from the hub? I just wanted to make sure I get the right amount.
You can have a zero offset and still have your backspacing change everything? A zero backspacing would push the wheel out 8" from the hub if it was an 8" wheel... am I correct?
I guess I'll make my own measurements and stop being a lazy butt asking dumb questions.
post #18 of 20 (permalink) Old 11-05-2009, 07:24 PM Thread Starter
5Greens's Avatar
Quoted: 2 Post(s)
amojohnny previously said: View Post
Thanks
Yes the lift came from Toytec 885s with ToyTec Top plate spacers for 3".
VT_RainMan previously said: View Post
There is 1" of space between UCA and tire. Spare tire fits on back just touches bumper I think the 1/4" might cause a problem there. I choose the Pro Comp wheel over the Wheeler's because Wheelers would not answer questions via email before the sale so I was concerned that if a problem came up during or after the sale we might of had communication issues. Shipping also increased over-all cost, but I really wanted "White" wheels. The local Pro Comp dealer did not charge extra for shipping and could test fit before sale.
5Greens is offline
post #19 of 20 (permalink) Old 11-06-2009, 08:39 AM
VT_RainMan's Avatar
Quoted: 0 Post(s)
^ Thanks for the post and pics 5greens.... that's exactly what I needed to know!
post #20 of 20 (permalink) Old 11-14-2009, 02:50 PM
Quoted: 0 Post(s)
Thanks 5greens. Just ordered me 5 87-6883t's. Apparently the t means toyota specific to clear the calipers. Can't wait. Thanks for the advice.
