Nah just bad fuel after some storms.Bugger. There are fuel to water separaters but I don't know it would have helped much with 5L of water! Are you sure it wasn't sabotaged?
This is what some of the Tacoma guys run
FST RPM300 for filtration and fuel/water separater but you still would have been SOL with that much water.
water separators with sight glasses are common in diesel and marine applications.
you can easily see if there's water contamination and take appropriate action. In this case it would have been to drain the tank into another container until the water stops...
Also - a length of fuel hose to allow draining...
Interesting fact - there is no fuel pressure in the FJ until you crank the engine...
Amazon.com: S3213 Marine Fuel Water Separator Filter Assembly with Clear Bowl 18-7922, 3/8 Inch NPT Port For Outboard Motor Mercury 35-60494-1 Yamaha Racor Sierra Engine Boat 10 Micron - Replaces B32013, 18-7932: Automotive
Buy S3213 Marine Fuel Water Separator Filter Assembly with Clear Bowl 18-7922, 3/8 Inch NPT Port For Outboard Motor Mercury 35-60494-1 Yamaha Racor Sierra Engine Boat 10 Micron - Replaces B32013, 18-7932: Fuel Filters - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
