1 - 14 of 14 Posts
A few questions as I am performing maintenance on my friend's 2007 auto trans FJ with 130k miles. It is a road car. However, it is located at 8000+ feet in Colorado with a long uphill gravel driveway. Obviously, it sees it fair share of snow.
1) with the hood up, the valve chatter a bit. Is this normal or do they require adjustment?
2) should antifreeze be replaced with Toyota OEM?
3) is there one part number for all the drain/fill plug washers /gaskets? If not, does someone have, for example, the AA part numbers?
4) below is a list of parts I compiled from various sources including this forum. Would you all have a look at it for me?
Any advice on what to purchase is welcomed.
Belt:
-AA part #5070835
Rear Wiper Blade:
-OEM #85242-35040
Air Filter:
-AA Part #88888
Engine oil:
-5.5 qts 5-30 Amsoil with filter
-drain Plug: 30 ft/lbs
-drain plug gasket 90430-12028 or 90430-12031
Rear Diff:
-3.1 qts 75-90 Amsoil
-fill & drain plugs: 36 ft/lbs
-gaskets: 12157-10010
Front Diff:
-1.5 qts 75-90 Amsoil
-fill plug: 29 ft/lbs.
-fill plug gasket: 12157-10010
-drain plug: 48 ft/lbs
-drain plug Gasket: 90430-24003
Transfer Case:
-fill & drain plugs: 27 ft/lbs
-Gaskets: 90430-18008
Transmission:
-3.2 qts ATF Amsoil
-drain plug: 15 ft/lbs
-check plug: 21 ft/lbs
-fill plug: 29 ft/lbs (o-ring)
-Gaskets: ?
-rubber o-ring: ?
-filter: AA part #96075
Power Steering:
- ? qts ATF Amsoil
Coolant:
-drain plugs: 10ft·lbf, 13 N·m
-10.4 qts Toyota antifreeze
Spark Plugs:
-14 ft/lbs
-gap: 1.1mm, 0.044"
-Denso K20HR−U11
-NGK LFR6C-11 (AA part #7787)
Note:
- Amsoil implies synthetic
- AA = Advanced Auto
I agree with the things that you listed. I replaced the radiator hoses at ~ 75k miles. That's mainly a throwback to when I lived in Phoenix, every other year the hoses and belts would get changed.
I installed magnetic drain plugs when I changed the gear oil.
Admin
It wouldn't hurt to clean the throttle body too... it's so easy and cheap to do I do that on a yearly basis.... and the MAF sensor.
Your friend is lucky to have you as a resource.
Where can I purchase a magnetic drain plug?
Discussion Starter #10
Good advice. I will change the hoses too. I will update the parts list with AA part numbers and repost.
Discussion Starter #11
Discussion Starter #12
How does one clean the throttle body and MAF? On my D90 I clean the throttle body with Gumout. The MAF?
I've been running Amsoil ATF for 9 yrs in my 07 FJ without any issues.
Add a PCV valve to your list -
NAPA ECHLIN# 2-9950 - $4
1 - 14 of 14 Posts
