1 - 2 of 2 Posts
I came across a set of Pacer Soft 8 Wheels.
All 5 for $200. brand new.
the question is will they fit?
Finish
Black
Hub Bore
108.71
Lugs/Bolt Circle 1
6X5.50
Offset
+12
Assuming they are 16"+ diameter and 7.5"+ wide, yes they will work, kinda.
Factory wheel is 17 x 7.5 +15mm offset, 6x5.5 lug, 106mm bore
They will stick out a whopping 3 mm further than the factory wheels assuming they are the same width. Your wheels with a 108mm bore may need these adaptors: https://www.ebay.com/itm/SET-OF-HUB-CENTRIC-RINGS-108-106-108MM-WHEEL-106MM-VEHICLE/133122051327?hash=item1efeb14cff:g:4DwAAOSwyUFcBYk~
IDK if the adaptors are necessary or if the wheel is lug centric. You may also need new lug nuts.
1 - 2 of 2 Posts
