1 - 5 of 5 Posts
Will these wheels fit with wheel spacers?
It looks like the only thing they are hitting is the caliper and the backing plate but with some wheel spacers will they fit?
I have a really good deal on wheels and tires that I do not want to pass up.
Has ANYONE run 15's or can ANYONE tell me if a wheel spacer will make these work.
I do not want to run out spend money on spacers just to find out they wont work.
If so, what size of wheel spacer have you used/ would you recommend?
Thanks in advance, rob.
I doubt they will work even with spacers. The diameter is the problem. The 16" wheels have barely 1/4" clearence for the calipers.
yup...i highly doubt they will fit. i already had a set of wheel weights ripped off my stock 16" wheels by my front brake calipers. i will note that the weights looked like long tootsie rolls and were placed right inline with the caliper.
Don't think they'll fit even with a spacer, probably the only way to fit a 15" wheel is to get smaller brakes, but that isn't really recommended, especially if you have an over weight FJ.:simmadown:
1 - 5 of 5 Posts
