1 - 7 of 7 Posts
Will it work OK on my 2007 FJ?
Tire size is 285/70 series plus leveling kit.
Any insight would be greatly appreciated!
Yes, 285/70-17 is about 32.7" tall, which is about 1" taller than stock. 9.0" +0 offset should be ok, even at full lock. Tire side wall to fender edge is about .75" past fender.. should look really good! :)
^^^Thank you for the response. I was hoping that would be the answer (or at least something close). I have a set of flat black Gauntlets on order. Should be here by weeks end and I was hoping I didn't go wrong with sizing.
Now I just hope they look good.
Post up some pics once you get them installed! :cheers:
I have very minor rubbing on the body mount. I have yet to determine if it is actually the mount or just the mud flap. In either event, I get a minor rub and the it goes away when I turn it to almost full lock.
Sorry for the video being a bit dark and the FJ a bit dirty. Cold, cloudy, and rainy here in CO today.
Looks good dude!! :clap:
Have a buddy help you to check where is rubbing. Just turn the steering wheel slowly till it reach full lock, you should be able to see where it's rubbing. :bigthumb:
What's the next upgrade? :)
1 - 7 of 7 Posts
