1 - 7 of 7 Posts
On a 2007 FJ
KING front coilover
Where do the brackets for the reservoirs mount?
I have non adjustable King shocks on my 07 and the resi brackets are also mounted under the sway bar mounts :)
Hmmmm.......I removed the sway bar and the hardware is long gone.
I bet you could just get a couple of bolts and thick washers and they would still mount up just fine :) I don`t think the sway bar mounts are holding the bracket on I think that's just where the brackets needed had the room to go so they put them under the sway bar mounts.
Cool, if I pull the trigger on these it will another trip to the bolt isle at Home Depot.
1 - 7 of 7 Posts
