2007 FJ Cruiser $221,XXX miles, 4WD, rear locker (works), Voodoo Blue, ARB bull bar, 8000# Ramsey Winch. Convenience package and the off road package #2. Running boards. Transmission does not, nor has it ever shuddered while I’ve owned it. Orange stuff in the undercarriage photos is the local orange clay, not rust.
best to email at cp.brown at me.com
The Good
The Bad
The Good
- Southern car, no rust
- Clean Carfax
- Hollandia 700 Sunroof
- TRD Exhaust
- TRD Cold Air Intake
- Rear locker works. We make a point to engage it about once a month.
- CV boots are good
- Inners repacked/rebooted by me at 208791 miles
- Outers repacked/rebooted by PO
- Both rear bearings have been replaced at 211023 miles with OEM Toyota
- Both rear axles seals replaced at 211023 miles with OEM Toyota
- New Powerstop rear rotors and pads at 211023 miles
- Replaced both rear parking brake shoes at 211023 miles
- Rebuilt both rear brake calipers at 211023 miles
- Front Diff fluid changed at 208442 miles
- Rear Diff Fluid changed at 211023 miles
- Transfer case fluid changed at 208442 miles
- Transmission flush performed at dealer at miles
- New hood struts
- Replaced cabin air filter at 208360 miles
- New OEM Toyota lower oil pan at 213638 miles
- Oil pickup screen cleaned at 213638 miles
- New rear Rancho shocks at 211023 miles
- New front coilovers (shocks & coil springs) (Dobinson) at 218752 miles
- New sway bar links at 218752 miles
- Spark plugs replaced at 208442 miles
- Rear axle breather extended
- New OEM Toyota thermostat at 220547 miles
- New OEM Toyota radiator cap at 220547 miles
- New OEM Toyota PCV valve at 221438 miles
- New OEM Toyota Evap Canister at 216124 miles
- MAF cleaned and new o-ring at 216124 miles
- Throttle body cleaned at 219308 miles
- New OEM Toyota Fuel Filler Neck at 219435 miles
- New OEM Toyota vapor Purge Valve at 221438 miles
- New vapor purge valve hose.
- New OEM Toyota exterior door handles
- New OEM Toyota Interior Door handles
- New blend door actuator at miles
- New seals on the sunroof at 220547 miles
- Sunroof drains cleared at miles
- New ARB marker lights in the ARB bull bar
- Blackstone Oil Analysis indicates normal engine wear for the miles
- Has optional rubber mat in cargo area
- Last oil change conducted at 219,139 miles
- All axle zerks greased at every oil change while I’ve owned the car
- 3 keys
The Bad
- Code P0456 (very small emissions leak) is turning on the CEL
- Subwoofer does not work
- Keyfob does not work
- Minor Rear Main Seal leak
