Hello-
I have a 2008 FJ 4WD with 160K miles and the suspension is starting to feel a bit sloppy. I am looking at this kit- and comments or advice? Anything else need to be changed out at the same time?
Kit includes:
-2 Bilstein front shocks (6112's)
-2 Bilstein remote reservoir rear shocks (5160's)
-2 red front coil springs (1" taller than stock - LEVELS IT OUT)
-all hardware to put everything together and mount everything up.
I just bought this setup and it arrived yesterday. I installed the rear shocks and went for a quick drive, before installing the front. VERY happy!
My FJ is an ‘07. A few months ago, I installed a lightly used set of Toyota Bilstein TT 5100 shocks from a 2014 TT all the way around, and was actually quite thrilled with the ride. At the time, it made me wonder why people upgrade this setup so soon.
Then the suspension that you posted above came up for sale, and somebody on the forum informed us about it with a post. I couldn’t pass it up, even though I recently installed shocks. I had to buy my kit on eBay because this deal isn’t available in Canada( that me or the Toyota dealer was aware of..one AWESOME forum member offered to get them for me and ship them to Canada, but I’d already bought them on eBay before reading the PM that she’s sent me..THANK-YOU again for your generous offer Deb
So like I said, I installed the rear yesterday afternoon. It was time to do the front end after supper and putting my daughter to bed because it was already close to 10pm.
I pulled everything apart on the passenger’s side only to find that my tophat was fused by rust to the spacer lift that was installed on my FJ by the previous owners. I couldn’t get them apart, which means I’d have to install them with spacers for now and order new tophats?..I installed the passenger’s side, going to do the driver’s side today. Tophats will be here Friday, and then I get to do it all over again??. At least I get more practice this way
Buy that kit if you’re considering a suspension, especially in that price range! You will instantly feel and hear the difference from the stock setup.
Be aware the the front lower LCA shock mounts on our older FJs are about 2mm narrower than the metal bushings on the bottom shocks mounts, so you will either have to grind 2mm off the metal on the bushings, or slightly open the gap on the LCAs.
You may also want you also look at all the fasteners for the shocks, and make sure that they aren’t seized and are reusable. If not, then order the extra little bits you need before you start the install, so that you are able to complete the job in one shot.
For now my nose is riding high until my parts show up..good thing I don’t work today!
Here’s some pics for you:
By now it was 11:30 PM so I left the driver’s side for today.
Sent from my NiPhone using Tapatalk
