1 - 8 of 8 Posts
This is my 2009 FJ Cruiser build up.
After market and new parts:
RadFlow
Adjustable (approx, 2.5" lift), extended travel front coil-overs 2.5" shock body, 650 lbs springs
2.5" shock body rear shocks
Rear Coil Springs 2" lift
JBA Offroad, (Jeepin' by Al)
JBA Heavy Duty High Caster Upper A-Arms
OEM Parts replaced
Front Lower Control Arms
Tie Rod Ends inner and outer
New front axles
Larger Oil Filter (M1-209A)
OEM Roof rack
OEM Rock Sliders
Metal Tech
BMC (Body Mount Chop Kit)
Cali Fab
Adjustable rear lower links, Johnny Joints on frame and polyurethane on axle (polyurethane greased with clear silicone grease, all other grease made terrible noises)
Adjustable rear Upper links, Heim Joints on frame and polyurethane on axle (polyurethane, silicone grease)
Adjustable Pan-hard bar, Heim Joints
Bora
3/4" wheel spacers
Tires
BF Goodrich KO2's, All Terrian TA's, 285/75/R17 (34 inch) (these wouldn't fit on mine with out the Bora spacers and BMC kit mentioned above)
ECGS (East Coast Gear Supply)
4.56 Nitro gears, front and back, (of course)
Hypertech
Inline Speedometer Calibrator
RESZ Fabrication
V2 "Core" FJ Cruiser steel bumper
Puer FJ Cruiser
FJ Cruiser Quick Release Hitch System
AFE Power
Cold air intake
Hi Tuck Cat back 2.5" exhaust
Hi-Lift
36" jack, neoprene boot, Off-Road Base, Lift-Mate
Mounted in rear, ratchet strapped to the d-rings right behind the carpet next to the back seats
Radio
Soundstream, VRN-65HB, (Not recommended, sound is great but they can't get the time correct! It's 2020 for gosh sake!)
OEM Parts modified
I had to modify the spare tire carrier to fit the 285/75/R17's. I removed the carrier and drilled four new holes about 1/2" down so that I could mount it about 1/2" higher. I had to make a cutout for the rear wiper to clear the carrier. I installed a 1 3/4" wheel spacer to the carrier and the spare to the spacer.
Installed LED lights throughout the interior.
Some Pictures of my FJ, I named it "FURY", cuz I liked that movie :)
Before any mods:
1123317
During and after mods:
1123318
1123319
1123320
1123321
1123322
1123323
1123324
1123326
1 - 8 of 8 Posts
