Rear is in! So front is a little higher. Hoping with settling/ bumper/ winch/ skids/ sliders it’ll be more level.
Worst case I get heavier weight springs.
Same bumper I went with but I went steel. So an additional 30-40lbs.I used 885 and 895 springs, got very close to 3" in front and it all came out pretty level. With the addition of a Coastal Offroad bumper (in aluminum), Warn M8000 winch (synthetic line), 20" led bar and a pair of 4" pods I haven't noticed the front end sagging at all, but I also haven't bothered to take a tape measure and check.
While up there, the cv angles have so far survived fine. I've had 1 torn boot which we replaced. And yes, SPC uca's went in when we did the lift. A piece of advice- grease the ball joints often.Same bumper I went with but I went steel. So an additional 30-40lbs.
How are your cv angles? Did you do new upper control arms?
I didn’t order uca’s yet as I wasn’t sure if I would really need them. Going to see how alignment goes and go from there.While up there, the cv angles angles have so far survived fine. I've had 1 torn boot which we replaced. And yes, SPC uca's went in when we did the lift. A piece of advice- grease the ball joints often.
With close to 3" of lift you will need them. People typically find that more than 2" and stock alignment settings (especially caster, which gives a vehicle higher speed stability) can be difficult to reach. You can use the lower control arm adjustment cams to move the wheel/tire forward a little to clear the body mount with taller tires, but now (without aftermarket uca's that have more caster to start with) coming close to stock alignment #'s becomes very difficult, and you really do need at least 2 1/2 degrees of positive caster if you want your FJ to be easy to drive on the highway. I've driven a car with not enough caster and at highway speeds you're constantly over-correcting. By the time you reach your destination on any long trip (more than an hour or 2) you're already half- worn out. It's also dangerous- there's a reason all cars and trucks are built with the front alignment specs they come with.I didn’t order uca’s yet as I wasn’t sure if I would really need them. Going to see how alignment goes and go from there.
Yeah guess I’ll have to watch my boots. Inner is my concern, outer looks fine. I have two new Toyota cv’s ready to go. Send off the others to cvj for high angle boots when they tear.
Yeah had the steering wheel turned to the right a bit that's all. Does make it look like that though.You look like you need a front end alignment your front tires look like they are not level![]()
Yeah I think I will order some. Lots of options out there. I actually cleared my 33's without a Body mount chop or lift so that's good.With close to 3" of lift you will need them. People typically find that more than 2" and stock alignment settings (especially caster, which gives a vehicle higher speed stability) can be difficult to reach. You can use the lower control arm adjustment cams to move the wheel/tire forward a little to clear the body mount with taller tires, but now (without aftermarket uca's that have more caster to start with) coming close to stock alignment #'s becomes very difficult, and you really do need at least 2 1/2 degrees of positive caster if you want your FJ to be easy to drive on the highway. I've driven a car with not enough caster and at highway speeds you're constantly over-correcting. By the time you reach your destination on any long trip (more than an hour or 2) you're already half- worn out. It's also dangerous- there's a reason all cars and trucks are built with the front alignment specs they come with.
Where did the alignment specs end up?Alignment actually went pretty well. Not that far off caster specs. Probably get some new uca’s anyways
100% have the needle bearing vibe. New ecgs bushing should be here Friday. Going to install that and a new wheel bearing on that side while it’s apart.
Everything green but caster out. 1.7 or so vs the paper saying 2.3 is green. Drives fine but going to get some uca’s anyway.Where did the alignment specs end up?
1.7 degrees caster is quite low, and you'll probably find it a little more tiresome to drive on long highway trips if you have a heavy foot...Everything green but caster out. 1.7 or so vs the paper saying 2.3 is green. Drives fine but going to get some uca’s anyway.
Yeah not ideal. No big trips soon. Plan is to finish everything by mid spring- early summer.1.7 degrees caster is quite low, and you'll probably find it a little more tiresome to drive on long highway trips if you have a heavy foot...
