2010 Brick build
2425 Views 33 Replies 4 Participants Last post by  brickedfj
Hello! Decided to make a build thread to keep track of stuff
Suspension:
-OME struts w/885’s
-OME shocks w/895e’s
-Dobinsons UCA’s
-Metalcloak rear lower control arms
-War fab tie rod sleeves
-Drt fab spindle gussets (need to install)
Armor:
-Coastal off road winch bumper with smittybilt x20 10k winch.
-1 3/4 OD DOM .120 homemade sliders
-RCI full skids
-Marlin Crawler LCA HD Brace/ cam gussets
Wheels/ Tires:
-Method 16x8 0mm offset 4.5bs
-315/75R16 Yokohama Geolandar MT g003
Future mods:
-4.88’s
-ARB front locker
-Tundra rack?
Here it is so far
Front lift install
Tire Wheel Automotive tire Hood Tread
Tire Wheel Vehicle registration plate Automotive parking light Car
Circuit component Coil spring Gas Electrical wiring Shock absorber
Reactions: 4
21 - 34 of 34 Posts
Painting in progress. Honestly decided not to grind down some of the outside welds. Mainly the wings. Didn’t really care either way and it was a lot of grinding haha.
Automotive parking light Tire Hood Automotive tire Automotive lighting
FedEx is an hour late with the skid plates…
Reactions: 1
Well skids came in.
Wood Gas Flooring Road surface Gadget
New issue…can’t fit the clutch handle in any direction apart from backwards.
Automotive tire Hood Motor vehicle Vehicle Bumper
Hood Automotive tire Bumper Automotive design Synthetic rubber
Lots of extra work to make the winch fit. For anyone else thinking about this bumper…Plan to Just relocate the control box under the hood so buy longer wires, cut out a portion of the top plate for the clutch handle. Clocking forward is a no go even after grinding the handle way down.
I didn’t have time to re wire longer cables so I basically cut out a light tab from the bumper and bolted the controller inside of the bumper wing. It works pretty well all said and done.
Also never ground down the welds the front pieces. Maybe one day. Not a huge priority.
Automotive parking light Tire Car Vehicle Grille
Automotive lighting Hood Trunk Motor vehicle Automotive tail & brake light
Water Automotive tire Fluid Asphalt Road surface
Road surface Rectangle Bumper Wood Automotive exterior
Hood Automotive tire Automotive lighting Motor vehicle Automotive design
Some basic sliders. 1 3/4 OD .120 DOM. Just welding them to the frame.
Basically wanted them out far enough for step access to put stuff on the roof. Angled up slightly.
Automotive tire Road surface Asphalt Motor vehicle Floor
Automotive tire Motor vehicle Hood Automotive lighting Bumper
Reactions: 3
Had been hearing noise from somewhere up front. Jacked the front up and wow the driver side tire had a ton of play from the wheel bearing test. So loud and a lot of movement by hand. Had bought some pre assembled with koyo bearings a few months back because I knew they would go soon.
Have some Dobinson uca’s on the way. Also added some tie rod sleeves. So when I blow the rack I have a good excuse for a tundra rack swap haha.
Automotive tire Bumper Bicycle part Gas Automotive wheel system
Reactions: 3
For anyone interested in the wheel bearing noise.
Reactions: 1
Finally bought some upper control arms. Went with Dobinsons. Wanted quiet, low maintenance oe style ball joint and bushings. I’ll post some Alignment numbers next week.
Tire Wheel Automotive tire Tread Motor vehicle
Sliders came out great too
Tire Wheel Car Land vehicle Vehicle
Reactions: 2
Marlin LCA HD brace. I did have to modify my RCI skids.
Automotive tire Hood Automotive lighting Bumper Wood
Automotive tire Automotive lighting Motor vehicle Hood Vehicle
Reactions: 3
Before/ After with lift and no UCA
Font Handwriting Parallel Paper Paper product
Before/ After with lift and UCA Dobinsons
Font Material property Parallel Handwriting Rectangle
Didn’t drive terrible before but drives straight with a lot less constant input now for sure.
Reactions: 1
Body mount chop today.
***. This was not enough. Did the angle wrong. Had to chop a bit more and still not done.
Automotive tire Tire Tread Automotive exterior Bumper
Did a thing. 315/75R16’s. Method 701 Yokohama geolandar Mt g003.
Drilled 4 new holes in the tire carrier. And just barely fits! By the skin of the new tire danglies.
Reactions: 2
Metalcloak rear lower control arms. 1.625 OD and 1/4 wall. Beefy. Their joints are awesome too. Improve flex a lot. The stock joints on the lowers bind terribly.
If used with RCI lower rear link bracket skids you will have to grind/ cut off some of the bracket to make the joint fit.
Reactions: 1
Threw on a power steering cooler from @Iconic_ . Awesome bracket makes it very simple to place.
Reactions: 2
21 - 34 of 34 Posts
