Status
Not open for further replies.
1 - 2 of 2 Posts
2010 FJ Cruiser, 74,300 miles, 4WD, automatic transmission, titanium silver. It is fully loaded with convenience package, upgrade package 2, and tow package, clean title in hand. A-Trac, rear diff lock, factory 8-speaker plus subwoofer audio system, rearview camera, parking sonar, and much more.
I am the second owner, bought the car in Feb 2013 from first owner. I now need a pick up bed. Car has always been garaged, in great shape, never had any issues, everything works as intended, no smoking. All maintenance done religiously with synthetic fluids only and ahead of factory schedule (oil, trans fluid, brake system, power steering, all differentials, prop shaft, coolant). I have a detailed word document for the maintenance done. Has K&N drop in air filter in factory box. Tinted windows. Recently replaced front brake pads with TRD brake pads. Just completed alignment at Big O in Sandy and just completed a full interior and exterior detail performed including 4 step paint correction finished off with a synthetic paint protection. Sitting on 305/70R17 Goodyear MTRs. Lift set at 3”. Undercarriage skids have some trail rash. Car is not my daily driver so miles will not go up. Car overall is in excellent shape. Expect some minor dings and very few minor scratches as normal for a 10yr old car
List of current mods:
ICON Rear Long Travel kit Stage 3 with Metal Tech Offset Rear Lower Links, Heavy Springs w/ ICON 2.5" Remote Reservoir Shocks
ICON 2.5” front adjustable coil-overs 58646
Total Chaos UCAs
All Pro spindle weld-on gussets
All Pro sway bar end-links
SS extended brake lines throughout
The Retrofit Source HID plug&play conversion with 55w bulbs (Morimoto projectors and LED halos in blacked-out OEM housing)
Budbuilt full undercarriage skids
Boztec Rear diff skid
AllPRo bolt-on sliders
Expedition One WyoOtto Bumper with Warn Zeon 10-S with synthetic rope 10,000lbs and PIAA 5190 510 SMR Series Extreme White Fog Lamps
Blue Sea Systems remote fuse box mounted inside cabin makes for easy and clean install of any electrical modification you might want
1144379
1144380
1144381
1144382
1144383
1144384
1144385
1144386
1144387
1 - 2 of 2 Posts
Status
