Im looking for some info on the immobilizer system and possibly the fuel pump cpntrol module and how they function.
I drove it to work today without issues. When I started it on lunch it reved up like normal and idled for a second and shut off. After that it was just a solid and healthy crank no start.
If it sits for 5 minutes or so, I do hear the fuel pump prime , and it will start for a moment and then die.
It will stay running on an alternative fuel source so Im positive I've got spark.
Seems to me there is something interrupting the signal to the pump. It will prime without issue every attempt as long as I let it sit a few minutes in between tries.
I only got as far as testing for 12v with key on at the fuel pump module, and making sure the constant ground had continuity.
I also swapped the fuel pump relay around and that did not help.
They flashing key on the dash does go out when I key on.
I have a Modis scan tool and it says that the immobilizer is disabled in the information field displays ( not positive I trust this completely and do somewhat suspect a faulty key, also do not have a second key to try )
Any thoughts or ideas greatly appreciated , could not find and TSB or tech tip regarding this issue either.
I also tried repetitive arming and disarming the alarm with the fob, and no change.
