How did you know it was your wheel bearings? And which side? When you're running, does it go away when you turn?
Negative, just cleaned er out real good and re sat the spring band cleaned the mate face and rolled on.You did pull the axle so you could replace that damaged “dust” seal from the back side of the knuckle, right? Use the tin axle nut cover as your seal installer😏
Jack it up so both front tires are off the ground grab the spring and spin the tire. Dry bearing will transfer a lot of harshness out that way to the point you can feel it. Mine was sending enough droning vibration into the cabin that initially thought u joints, but I was only in 2wd so that u joint was not spinning. Longer sweeping highway corners could feel a change and then it would come back when I leveled out again.How did you know it was your wheel bearings? And which side? When you're running, does it go away when you turn?
We will include that test when we take in my friend's new 2012 FJ project. The tires are due so he ordered a set from 4Wheelonline along with new calipers and brake pads.Jack it up so both front tires are off the ground grab the spring and spin the tire. Dry bearing will transfer a lot of harshness out that way to the point you can feel it. Mine was sending enough droning vibration into the cabin that initially thought u joints, but I was only in 2wd so that u joint was not spinning. Longer sweeping highway corners could feel a change and then it would come back when I leveled out again.
