1 - 5 of 5 Posts
My 2011 with stock off road suspension package sits about an inch lower on the driver rear side than on the passenger rear as measured from the fender to the top of the rim. Is this normal? The ground I am parked on is leveled so I am not on a slope.
The battery, 19 gallons gas tank, and tire are all offset to the drivers side of the vehicle. A slight lean to the drivers side is pretty normal.
welcome to Toyota...when you own a Tacoma, it's affectionately referred to as "Taco Lean". You can buy a shim if you want to insert and level it out. When I lifted my Tacoma I did that and it worked well.
1 - 5 of 5 Posts
