1 - 3 of 3 Posts
I've searched and reviewed threads on the subject many times. (The new search function is great) The threads that look helpful all have broken image links.
I just need to remove the original bottle and replace it with same OEM bottle.
Is removing the OEM bumper required?
In the wheel well I can that the bottom of the front looks like it can be removed. I know there are three bolts but I can't see, don't know which ones.
I just don't want to tear it all apart not knowing what is needed.
Pictures pointing out the bolts and a little know how to would be great.
I'd do it for you (big grin if we had it)
Lee
No pics, just instructions: You don't need to remove the bumper, only the front lower part of the inner fender liner needs to be disconnected, bent (flexed) out of the way so you can access the 2ea 10 MM bolts that hold the bottle in (1 low, 1 high). The upper bolt will be a tight squeeze and you may utter a few colorful remarks when you try to get a wrench on it.
Got a little frustrated with the whole deal. Let my Toyota dealer do the R&R. Only an hour charge.
Not a body and fender guy
All better
1 - 3 of 3 Posts
