1 - 18 of 18 Posts
Selling my 2014 FJ Cruiser TTUE. This vehicle was bone stock at 52,000 miles and it now has just under 53,000 miles. All of the mods were done with new parts and the truck hasn't had many miles put on since the buildout. With the new suspension, the truck sits 2" higher than stock in the front and 2.5" in the rear. Runs and drives great and is in excellent shape inside and out. I've invested more than $12K in parts alone in this build, along with many nights and weekends of labor.
I had this posted on the forum last year. Since then I've put less than 200 miles on the truck, replaced the needle bearing in the front differential with an ECGS bushing (to correct a slight vibration between 40-60mph), and treated the frame, suspension components, and axle housings with Eastwood Rubberized Rust Encapsulator to take care of surface rust from a few PA winters. The only issue I'm aware of is slight tire rub on the body mount in certain circumstances - it could use a BMC.
Needs a new owner to take it on camping trips and outdoor adventures. Happy to answer any questions or take additional pictures, if requested. Clean carfax report. PA title in hand.
Price: $36,000
Armor:
Front Bumper: Ex1 Kodiak (Steel)
Rear Bumper: Ex1 Trail Series (Steel) w/Swinging Tire Carrier, Backup Camera, Hi-Lift Mount
Rock Rails (OEM)
Full Aluminum Skids (OEM TRD, RCI ,Ricochet combo)
Shrockworks Rear Link Skids
Suspension:
Front: Radflo 2.5" Extended Travel Adjustable Coilovers & Total Chaos Uniball UCAs
Rear: Radflo 2.5" Extended Travel Shocks, 2" Lift Springs, Metaltech Lower Links
Tires:
(5) Wild Country XTX, LT285/75/R16, Load Rating: E (less than 250 miles)
Recovery:
Warn Zeon 10-S (synthetic rope)
Factor 55 Closed Link Hook
Shrockworks Winch Kill Switch
Crosby 3/4" Shackles
Hi-Lift Jack
Lights:
Front : PIAA LED LP530 Fogs
Rear: PIAA LED 3.5" Floods
Interior:
Rugged Ridge Floor & Cargo Mats
Console Vault
Springtail Molle Panels & Basket in Cargo Area w/Storage Pouches
Other Mods:
Tow Hitch Added - Toyota OEM Hitch & Wiring
Transmission Cooler Added - TruCool 4454
Breathers Extended to Engine Bay (Rear Diff, TC, Front Diff, Transmission)
ECGS Bushing Installed in Front Differential (Replaced Needle Bearing on Driver Side)
Rad Rubber Splash Guards
Ex1 Washer Bottle Relocate Kit
Warrior Diamond Plate Trim
Maintenance:
Fresh Motor Oil & Filter
Fresh Gear Oil in Both Differentials & Transfer Case
New Optima Yellow Top Battery
Price drop: $35,000 as she sits. $34,000 without the winch, shackles & high lift jack.
Here’s a past shot of him and one of his brothers.
Another past shot of him with one of his other brothers.
Discussion Starter #18 (Edited)
Will consider trading this beast for a Toyota 4Runner. Interested in TRD Pro in Calvary Blue, Cement Gray, or Quicksand or a well built MGM. We can start with Blue Book + reasonable value of mods and come up with an agreeable deal for both parties.
I figure most of the guys on this site are Toyota guys that know other Toyota guys, so spread the word.
1 - 18 of 18 Posts
