1 - 17 of 17 Posts
hi all well i just order some new wheels for my FJ and i also ordered some285/70/17 tires for the wheels, my question is i dont like the lok of nice rims on your can and having a spair tire that is a 265/70/17 and a tire cover, so
my question is can i fit a 285/70/17 tire on the back door of the fj with out any problems or will wil the tire rub on the top of the bumper.
i dont want to go waist $$$ buying a spair and it turns out to be my living room table base :cheers::cheers:
I have that size tire on my spare. BFG mud terrain to be exact. nope, it does not rub on the bumper.
You'll be able to fit it on the back without issues. I haven't heard of issues with tires up to 305. Not sure of 315 though, it's gotta be very close.
thx all that makes me happy, now i can go buy this extra rim because they are low in stock and i dont want to wait another 3 months
just to make sure i am correct, is a 285 tire a 33" tire
Check out the tire size calculator posted in the sticky at the tire section of the forum.
i have but i wil again thanks
2.54 cm in 1 inch
285mm/25.4mm = 11.22" wide tire
11.22"x 70% (which is 0.70) = 7.85" tall side walls.
(7.85x2[for each side wall]) + 17"rim = 32.7" tall tire
This is how to calculate tire size from metric into inches, which is more desired from offroaders.
thank you =)
Discussion Starter · #11 ·
thanks all for the input
I have 295 on mine with no issues...about 1/8inch between window and about 1/4 between bumper.....think my 295x70x17 works out to 33.1 or 33.2
you will be fine.
Discussion Starter · #13 ·
cool thx u this helps alot so now i can go order that other rim, what lugs do u guys use on your rig that have rims, i was thinkin about using gorilla, but i dont know there ratio of keys (meaning for every 1000 keys they use the same key again)
Keep in mind that just because a tire says 285 doesn't mean it is exactly 32.7 or that a 33 is exactly 33. It maybe a 33 is actually 32.4" in diameter.
I have the stock lugs on the alloys and acorn style gorilla lugs in 12x1.5mm on my pro com steelies.
Discussion Starter · #15 · (Edited)
i will be getting the BFG A/T does anyone kno the size of those, well to tell you the truth now that i kno they fit it really does not matter lol
those in a 285 fit without body mount chop on mine. Tincan runs them and says he has a little rub a full turn. Only difference between our rigs is i have OME lift.
Discussion Starter · #17 ·
i just want to make sure they wont rub on the body mounot, i know this is discussed alot on the fourm but some say no and some sa yes. does anyone have 285 BFG a/t with a 3" fox lift? if so do u rub in the front on full lock?
1 - 17 of 17 Posts
