21 - 39 of 39 Posts
BFG 285/70/17 AT's with OME lift.
check my sig
where did u get stickrs
Yep, that's what a 3" lift will do to your pics. :)
If you're using PhotoBucket, you can select the size you want to upload for posting on the Upload "options" screen.
640x480 (works best here for the Forum)
320x240
160x120
Thanks for the tip! Dang that's a sweet rig we have! :D
Donahoe coil overs in the front, OME rear springs and Blistein external resevoir shocks rear. I'll add some more pics.
285/75/16 with a ome lift....
Thanks hockey-a spacer should give the same look. I did have some body mount rubbing issues (some do, some don't) and had my body mounts chopped-that was an extra $200. It only occured with braking turns like pulling into a parking slot. Post up when your done!
Discussion Starter #39
it'll be a while i;m gonna wait until my current tires run out
21 - 39 of 39 Posts
