I finally had a chance to install my Fox Shox 2.0 Front Coilovers and Rear Shocks this past weekend and it's now for my next mod. My ride does look bad-ass w/ the 3" lift and w/ my TTSE wheels wrapped in 265 BFG AT tires but it's still not enough for me. I would most likely go with Nitto Terra Grapplers but I don't know what size I should go with, 285 or 305? Keep in mind, this is my daily driver and I do go offroading when time permits.
Here are a few questions I need help answering before I can make up my mind:
1) How much mpg would I be loosing - 285? 305?
2) Is a body mount chop required for 285? 305?
3) Will I encounter any rubbing on 285? 305?
4) Are spacer (front and rear) required for 285? 305?
5) Is there any other mods required for 285? 305?
6) Is there any strain to the suspension or body for either 285 or 305?
7) Do I need to change my gearing for either 285 or 305? If so, how much would that cost me for parts and installation?
8) Which tire size do you recommend?
That's all the questions that I have so if you can help me out, I would definitely appreciate it.
