1 - 6 of 6 Posts
Hi,
Looking for a solution to mount a 37" BF Goodrich Tire onto my FJ Cruiser (likely need a creative/custom option).
Criteria
Safety/weight on back door is priority
Seen hitch racks from Rigd Supply but it blocks backup sensor and extends too far out.
Ideally like to keep backup sensor (and not camera sensor)
Do not have budget for steel bumper
If anyone has any suggestions or recommendations, would love to hear it. If you have successfully mounted these regardless of method, please let me know your feedback and pictures would be great.
Thanks in advanced.
You can copy my idea. Though if you don't have the tools, may cost you more in the end. BFH, angle grinder, dremel, spacer and hardware. I used a 1.25" spacer but you could fit a 1" depending on your wheel width and offset.
1128464
1128465
The other option is the least expensive and the Warrior Products mount only uses three bolts to hold on and would shake the spare every time I close the rear trunk
1128466
Good luck
Good luck
Thanks!
Appreciate the response but doesnt this method still put stress on the rear door?
1 - 6 of 6 Posts
