3D Printed Rear Door Latch release + lock switch
50069 Views 323 Replies 180 Participants Last post by  Hannibal
10
Hey everyone. First time posting here, but it's been an amazing resource for me so I wanted to give back. There have been several posts about this already and I want to thank especially WESAYSO and SONOF40 for the inspiration. I'm preparing to do more car camping with my FJ cruiser, so in anticipation of sleeping in the cab I needed a way to exit. Here's what I did:
There's already a small access port in the bottom left of the rear door inside panel, so I calipered it and quickly modeled it in Sketchup to form my parts around. I modeled an inset port that has snap fit sides to sink flush into the existing opening. I also modeled a "button" that will gently snap in to the rails on the "port" and keep it traveling vertically, but with a loose fit as to not bind.
1163413
1163414
1163415
I was surprised this worked perfectly on the first try. But no complaints! I located the metal rod that moves vertically from the exterior handle and modeled a snap fit junction to intercept it with my own aluminum rod. The junction snap fits onto the existing rod and has a topside receiver for the aluminum rod I cut and bent to fit. This was a bit of a gut feeling shape. But in general I came up the length of the straight portion of the existing rod, then bent out and up 45 degrees, then back out at 90 degrees to the original rod. Basically targeting the center top of the existing opening. Then cut the excess off to slide into the rear of the button. The "junction' piece's rotation around the rods allows a little fore/aft play for connection, while keeping a rigid connection in the vertical axis.
1163418
1163419
1163420
(SEE EDIT BELOW) Next, I designed and printed a pull handle and created it to fit into the top left bolt hole that fastens the door cover on. There were naturally negative spaces on the left and right of the port for placing the snap in hole cover. I utilized these to keep the handle from rotating. Kind of a keyway design. One thing I struggled with was that the receiver for those two bolts is a plastic insert and I felt that yanking on the handle over time could weaken that, so I grabbed a 3" 5/16th carriage bolt from the HD that fit perfectly in the square hole of the door with the threads facing OUT. That way I can tighten the through bolt down from the outside for easy removal later. I had to remove the bracket from the door temporarily to install the carriage bolt.
1163424
Lastly, I basically did the exact mod that WESAYSO has posted, but placed the button under the pull handle to protect it from shifting cargo and prying eyes. 10 bucks on amazon for 5 3 position switches with male paddle connectors. Look to their post for details.
1163425
Ultimately, I think this recessed button design is the safest when it comes to shifting cargo. It seems very unlikely that anything would poke into a small opening AND push down, so I feel confident I won't lose my cargo all over the freeway. Here's a video of it in operation. Thanks for reading!
Edit: If you'd like to print your own kit, here are the STL files and instructions to bend the rod. I suggest printing in PLA+ or better. Also, print the port face-down, the button lying on it's back with support and the handle on it's side with support.
UPDATE PLEASE READ!
Hey everyone. I was never really thrilled with my pull handle design and after field testing mine for some time now I’ve decided to redesign it. It looked cool, but I feel like it didn’t have the proper strength for hard pulls. I was throwing it in free-of-charge for that reason when people requested a set from me. I’m no longer making this particular part for people, but I’ll leave the file there in the event it’s still desired. The door release mechanism has remained unchanged and appears to be working well for everyone!
Instead I’ve come up with this soft handle design that I think is less intrusive and far more useful. The only time that the handle has truly been necessary for me is when bedding down for the night and needing to pull the door closed, so the distance to handle when standing on the rear bumper wasn’t ideal. The idea behind the soft handle is that you can clip longer webbing/rope to it when you want to pull from inside the truck. I had to source additional hardware and webbing for this design so if you’re interested in one, let me know. I have Black, Blue, Red and Orange webbing available.
Tool Font Electric blue Cylinder Auto part
Automotive tire Hood Tire Blue Bicycle tire
One other thing! I know it’s not obvious, but if you’re new to the forum and you need to DM me for a request, you must FIRST post a reply in the forum here or anywhere and your DM capability will be unlocked.
Dallas
Reactions: 5
261 - 280 of 324 Posts
Thanks FJtest. Happy to. Here's a folder with the original Sketchup files and the associated STL files for print. Note that the FJ's existing rod is 5mm diameter, while I used 1/4" aluminum rod (6mm). If using any other diameter rod, you'd need to modify the clip and the button hole to reflect that diameter.
Thank you Dallas. You addressed a problem that was in desperate need of a solution and did so with a great design and result. Of the files posted which specific files are for the purpose of the rear door button (not the handle design) . Thank you again for your sharing.
The handle is a single object. It just requires a bolt, washer and nut to install. The mechanism for door release consists of the Port, button, link and aluminum rod. Ideally the port prints with the bezel face down on the bed. The button prints with support laying on it's back. The link prints on end with the hole facing up. Is that clear? Let me know if you need more info.
Reactions: 2
Hey everybody.
I just popped up to Yosemite to sleep in my truck and try out my latch and came back to this. I'm flattered. I'm pretty busy, but I'm going to try to make these for everyone if you don't mind being a little patient. If all of you who are interested in a set don't mind sending me a PM with your specific colors listed that would be helpful for me to organize this. Please specify if you would like the Handle. It's the longest part to print, so if it's not desired it'll speed up the process for me significantly. So let's format the request like this:
Handle - Yes/No. If yes, Black, Grey, Red, Orange, Blue, or White?
Port color - Black, Grey, Red, Orange, Blue, or White?
Button color - Black, Grey, Red, Orange, Blue, or White?
The internal linkage will be whatever color was on the printer last, but won't be visible. Finally, as everyone has suggested, $20 seems reasonable for the effort, so that's what we'll do. But I'll go ahead and include the aluminum rod already bent to match mine so you won't need any additional materials to install. All snap fit for the release parts.
Thanks!
Dallas
Hi I'm interested in purchasing one of these latches from you. That and the closing handle. Could you all black will be fine. Text me at 336-516-5358. I appreciate it! I can pay with PayPal or whatever works best for you
Reactions: 1
...I wonder if folks posting to this will ever read the beginning of this thread which includes all the details how to contact Dallas and order these.
Reactions: 1
Ha. I know. I've just kind of decided to check up on the forum from time to time and DM people who express interest in the comments. I'm sorry that you have to keep seeing the carnage!
Reactions: 1
Dallas…. Awesome product. Just wanted to say thank you brother !!!
Reactions: 1
I love this idea, would I be able to buy these parts from you?
Hey everybody.
Thanks!
Dallas
Can I put in an order please?
Handle-no
Port-grey
Button-grey
Reactions: 1
6
Follow up, 1 year later: the RP internal remote latch lever, and pull handle are both still working great, but I found one improvement for the handle. The concern is that it kept coming loose, and re-tightening the nut eventually cracked its base. So, I added a steel collar to take the load instead of just the plastic.
Background: resin under continuous load will creep over time (or bend and crack), the column loading from the center nut/washer caused mine to become loose and cracked the handle (as did using it to pull the door closed).
Adding the steel collar allows the steel to take the nut / screw torque (and the door pulling force) and the epoxy holds the resin handle to that (similar to how an OEM would do it, except they’d use a knurled spacer and insert it with heat).
Here's how I did it:
Back Door Handle updates:
1) I added a radius to the sharp edges (with a file), just for comfort while using it.
Wood Bicycle part Thumb Electric blue Auto part
Finger Bicycle part Bumper Wood Electric blue
2) bore out center hole from 15/32” -> 1/2” so that commonly available hardware store spacers will fit.
I used a pair of 3/8" ID x 1/2" OD x 1" long galvanized steel spacers as the inner steel collar.
3) because the spacers are 1" long I used two of them and then increased the depth of the counterbore (visible in the photo above) +1/8” deeper, so the resulting center hole length is 2” long (original was 2 1/8”). I used a 3/4” spade bit (not pretty, but effective enough as a face bore in this case). Make sure the spade bit does not have spikes at the ends of its wings (you want a flat for the washer to lay on).
4) buy 2 of 3/8” x 1/2” x 1” galvanized steel spacers
Wood Rectangle Electric blue Font Sleeve
5) score little “x” shapes into the outsides of the spacers, all around their outer surface with a hack saw for the epoxy to key to
Automotive tire Wood Rim Automotive exterior Automotive wheel system
Water Automotive tire Wood Gas Bumper
6) epoxy the spacers into the center hole (make sure the washer is seated fully onto the new counterbored surface). I used a suitably sized socket to push down on a bolt through the center hole, and then squoze the epoxied assembly lightly in a vice until the epoxy cured. The goal is for no gap between the spacers, the washer at the bottom of the counterbore and the other end of the handle, so the steel column takes all of the load.
Wood Automotive tire Button Electric blue Recreation
7) re-assemble. The result should be stronger and more long lasting (and more resistant to damage from normal use)
Norm
  • Helpful
Reactions: 3
This is amazing! Just got referred here from a YouTube video! Are these still available? If so, can I place an order? Handle, port, and button all in black? Thanks in advance!
Hey everyone,
Just posted my design for my sleeping platform if anyone is interested. It basically was the inspiration for this latch design. Just got around to writing it up. Maybe it'll inspire you, too!
Dallas
How much for the 3D printed rear door latch?
View attachment 1163413 View attachment 1163414 View attachment 1163415
View attachment 1163418 View attachment 1163419 View attachment 1163420
View attachment 1163421 View attachment 1163422 View attachment 1163424
Dallas
How much to buy your 3D printed items to open my FJ door?
I have a 2007 FJ and I am interested in purchasing of your recessed tailgate handles. Your invention is brilliant. May I purchase one from you?
Thanks,
Rich
Hey, great little trunk window hack! I love it! I have a great idea. If you send me one in black, I will install it as an episode to my Youtube channel. "FJ Cruiser DIY Guy", where I do upgrades to my FJ and show our fellow FJ'rs that not only can we do it ourselve's, but we can have fun doing it! In the video I will let everyone know who and where to pick this awesome DIY upgrade in the process. PM me and let me know if your interested.
A video has been done by @LiL13izzy7 (y)
3D Printed Rear Door Latch release + lock switch | Page 5 | Toyota FJ Cruiser Forum (fjcruiserforums.com)
__
Everyone needs to read the thread. Lots of info, links and videos to assist you.
ONE post is required to send a PM/Start a Conversation.
Reactions: 1
Thanks Scott! As Hannibal pointed out there already exists a pretty great install video by @LiL13izzy7. But maybe you could one-up him by printing the parts and bending the rod using the files I provided for a complete DIY experience!
Reactions: 2
Wow! this thing is wicked! I want one!
Handle - No
Port color - Blue
Button color - Orange
DM sent!
Great mod. Dallas. Unfortunately, I do not have access to a 3d printer, I was wondering if you can sell me a kit for the installation, I will appreciate the support.
