3D Printed Rear Door Latch release + lock switch
50071 Views 323 Replies 180 Participants Last post by  Hannibal
10
Hey everyone. First time posting here, but it's been an amazing resource for me so I wanted to give back. There have been several posts about this already and I want to thank especially WESAYSO and SONOF40 for the inspiration. I'm preparing to do more car camping with my FJ cruiser, so in anticipation of sleeping in the cab I needed a way to exit. Here's what I did:
There's already a small access port in the bottom left of the rear door inside panel, so I calipered it and quickly modeled it in Sketchup to form my parts around. I modeled an inset port that has snap fit sides to sink flush into the existing opening. I also modeled a "button" that will gently snap in to the rails on the "port" and keep it traveling vertically, but with a loose fit as to not bind.
1163413
1163414
1163415
I was surprised this worked perfectly on the first try. But no complaints! I located the metal rod that moves vertically from the exterior handle and modeled a snap fit junction to intercept it with my own aluminum rod. The junction snap fits onto the existing rod and has a topside receiver for the aluminum rod I cut and bent to fit. This was a bit of a gut feeling shape. But in general I came up the length of the straight portion of the existing rod, then bent out and up 45 degrees, then back out at 90 degrees to the original rod. Basically targeting the center top of the existing opening. Then cut the excess off to slide into the rear of the button. The "junction' piece's rotation around the rods allows a little fore/aft play for connection, while keeping a rigid connection in the vertical axis.
1163418
1163419
1163420
(SEE EDIT BELOW) Next, I designed and printed a pull handle and created it to fit into the top left bolt hole that fastens the door cover on. There were naturally negative spaces on the left and right of the port for placing the snap in hole cover. I utilized these to keep the handle from rotating. Kind of a keyway design. One thing I struggled with was that the receiver for those two bolts is a plastic insert and I felt that yanking on the handle over time could weaken that, so I grabbed a 3" 5/16th carriage bolt from the HD that fit perfectly in the square hole of the door with the threads facing OUT. That way I can tighten the through bolt down from the outside for easy removal later. I had to remove the bracket from the door temporarily to install the carriage bolt.
1163424
Lastly, I basically did the exact mod that WESAYSO has posted, but placed the button under the pull handle to protect it from shifting cargo and prying eyes. 10 bucks on amazon for 5 3 position switches with male paddle connectors. Look to their post for details.
1163425
Ultimately, I think this recessed button design is the safest when it comes to shifting cargo. It seems very unlikely that anything would poke into a small opening AND push down, so I feel confident I won't lose my cargo all over the freeway. Here's a video of it in operation. Thanks for reading!
Edit: If you'd like to print your own kit, here are the STL files and instructions to bend the rod. I suggest printing in PLA+ or better. Also, print the port face-down, the button lying on it's back with support and the handle on it's side with support.
UPDATE PLEASE READ!
Hey everyone. I was never really thrilled with my pull handle design and after field testing mine for some time now I’ve decided to redesign it. It looked cool, but I feel like it didn’t have the proper strength for hard pulls. I was throwing it in free-of-charge for that reason when people requested a set from me. I’m no longer making this particular part for people, but I’ll leave the file there in the event it’s still desired. The door release mechanism has remained unchanged and appears to be working well for everyone!
Instead I’ve come up with this soft handle design that I think is less intrusive and far more useful. The only time that the handle has truly been necessary for me is when bedding down for the night and needing to pull the door closed, so the distance to handle when standing on the rear bumper wasn’t ideal. The idea behind the soft handle is that you can clip longer webbing/rope to it when you want to pull from inside the truck. I had to source additional hardware and webbing for this design so if you’re interested in one, let me know. I have Black, Blue, Red and Orange webbing available.
Tool Font Electric blue Cylinder Auto part
Automotive tire Hood Tire Blue Bicycle tire
One other thing! I know it’s not obvious, but if you’re new to the forum and you need to DM me for a request, you must FIRST post a reply in the forum here or anywhere and your DM capability will be unlocked.
Dallas
Reactions: 5
281 - 300 of 324 Posts
@dallassterling Outstanding mod! I'm a little late to the party, but would love to get my hands on one of these:
Handle - Yes/No. If yes, Black, Grey, Red, Orange, Blue, or White? Black
Port color - Black, Grey, Red, Orange, Blue, or White? Black
Button color - Black, Grey, Red, Orange, Blue, or White? Black
4
@dallassterling
Received it, got it in (it's a struggle! lol), and it works great!
I opted for the blue with orange for matching and contrast, I think it looks dope as hell, thanks Dallas!
Automotive tire Hood Motor vehicle Vehicle Bumper
Automotive parking light Grille Hood Tire Automotive lighting
Rectangle Vehicle door Font Tints and shades Electric blue
Automotive tire Tire Motor vehicle Vehicle Automotive design
Reactions: 2
Wow! this thing is wicked! I want one!
Handle - No
Port color - Blue
Button color - Orange
DM sent!
View attachment 1163413 View attachment 1163414 View attachment 1163415
View attachment 1163418 View attachment 1163419 View attachment 1163420
View attachment 1163421 View attachment 1163422 View attachment 1163424
Dallas
Hey Dallas,
This is an awesome mod that I would like to put on my FJ. I'm looking for just the door release mechanism, not the handle. What would it cost to mame one up and ship to me? I'm not too sure how you can contact me, maybe msm? I would be interested in all black. I looked for the files, but can't find them. Pls DM me.
Hey everybody.
I just popped up to Yosemite to sleep in my truck and try out my latch and came back to this. I'm flattered. I'm pretty busy, but I'm going to try to make these for everyone if you don't mind being a little patient. If all of you who are interested in a set don't mind sending me a PM with your specific colors listed that would be helpful for me to organize this. Please specify if you would like the Handle. It's the longest part to print, so if it's not desired it'll speed up the process for me significantly. So let's format the request like this:
The internal linkage will be whatever color was on the printer last, but won't be visible. Finally, as everyone has suggested, $20 seems reasonable for the effort, so that's what we'll do. But I'll go ahead and include the aluminum rod already bent to match mine so you won't need any additional materials to install. All snap fit for the release parts.
Thanks!
Dallas
I’m super interested! I can’t figure out a way to PM. But if able I would like
Handle: black
Port: black
Button: black
thanks!
Hey Dallas,
Hey GGuindon,
Thanks. The files were posted on post #8 on the first page of this thread. I've edited the OP to include it as well. Here's the link again though:
In my spare time I'm still making them for forum members and asking $20 plus shipping (usually around $12 for UPS Ground in the US) for the trouble. I prefer to keep our communications here on the Forum. DM me if you're interested.
Reactions: 1
Dallas
Are you still making the door release? I can not figure out how to DM but I am interested in getting one from you.
Dallas,
I would love to get this mod in black if you are willing to make one. I have been searching for an elegant solution like this. New to the forum so not sure how to DM you.
Dallas,
DM is now on. Click on Dallas' username and Start Conversation.
Reactions: 1
That what I Looks for since I Bought my fj
Trying to send a DM but cannot
I hope you see my reply I want to order one 🙏
Handle - Yes/ black
Port color - Black
Thank you
New to the forum and tryin to jump on this bandwagon to get a hold of this fantastic mod if you are still making them.👌
Handle-white
Port-black
Button-orange
Reactions: 1
Dallas,
Package with mod has arrived. Thanks!
Reactions: 1
@dallassterling
I'm a new member down in Austin, TX and would love to order the following at your convenience:
Handle - Black
Port - White
Button - Orange
i would love to purchase a recess kit if you are willing to sell it.
Hey everybody.
Thanks!
Dallas
Hey Dallas, I'm wanting to get one of these kits from you but don't know how to PM you. Are you still able to make me one of these kits? Thanks, Eric
(sigh) perhaps we need to edit the first post to this (now 15 page long) thread, so that the (many) 1st time visitors to it can more easily learn how to send a PM to Dallas, to order a set?
Assuming Dallas is still actually making and selling them!
Norm
Dallas was on here 7 hrs ago so... @dallassterling shall we edit the 1st post or are you done with these?
Hey @Hannibal and @norm356 , I'm still at it. I've just been direct messaging those who don't understand the 1 post rule to get the conversation started. What do you suggest I do? Sorry if you're getting a million notifications.
D
Reactions: 3
