21 - 40 of 64 Posts
2011 FJ Cruiser Iceberg
Count me in if you have the time to do this. White would be my color of choice but, would be happy to go with black if that helps reduce cost.
Awesome job! If you make these available I would like the latch release in orange.
2014 Black FJC, Blacked Out windows, badges, TT door handles, mirrors, grill,
count me in too.... black or gray for me . Awesome work !!!
2010TT AT
Your solution is completely brilliant!
First, thanks for sharing the files.
If you do produce a run of latch kits though I'd be happy to buy direct - 'Discrete' black/grey would be fine.
+1 for black if these become available. Let me know because climbing over the front seat and trying to open the front door gets old.
I think you just opened up a can of worms! 😂 But, when you have FJ aficionados that are looking for the perfect solutions...well then...I think you can see what may come out of it.
You created a very clean and thoughtful design. It's the best I've seen done by a long shot! Excellent job and thanks for sharing your files. I just wish I had access to a 3D printer.
...and with all that said...
I'd also be interested in buying if you were to ever produce them! 😉 Seriously
Hey everyone. First time posting here, but it's been an amazing resource for me so I wanted to give back. There have been several posts about this already and I want to thank especially WESAYSO and SONOF40 for the inspiration. I'm preparing to do more car camping with my FJ cruiser, so in anticipation of sleeping in the cab I needed a way to exit. Here's what I did:
There's already a small access port in the bottom left of the rear door inside panel, so I calipered it and quickly modeled it in Sketchup to form my parts around. I modeled an inset port that has snap fit sides to sink flush into the existing opening. I also modeled a "button" that will gently snap in to the rails on the "port" and keep it traveling vertically, but with a loose fit as to not bind.
View attachment 1163413 View attachment 1163414 View attachment 1163415
I was surprised this worked perfectly on the first try. But no complaints! I located the metal rod that moves vertically from the exterior handle and modeled a snap fit junction to intercept it with my own aluminum rod. The junction snap fits onto the existing rod and has a topside receiver for the aluminum rod I cut and bent to fit. This was a bit of a gut feeling shape. But in general I came up the length of the straight portion of the existing rod, then bent out and up 45 degrees, then back out at 90 degrees to the original rod. Basically targeting the center top of the existing opening. Then cut the excess off to slide into the rear of the button. The "junction' piece's rotation around the rods allows a little fore/aft play for connection, while keeping a rigid connection in the vertical axis.
View attachment 1163418 View attachment 1163419 View attachment 1163420
Next, I designed and printed a pull handle and created it to fit into the top left bolt hole that fastens the door cover on. There were naturally negative spaces on the left and right of the port for placing the snap in hole cover. I utilized these to keep the handle from rotating. Kind of a keyway design. One thing I struggled with was that the receiver for those two bolts is a plastic insert and I felt that yanking on the handle over time could weaken that, so I grabbed a 3" 5/16th carriage bolt from the HD that fit perfectly in the square hole of the door with the threads facing OUT. That way I can tighten the through bolt down from the outside for easy removal later. I had to remove the bracket from the door temporarily to install the carriage bolt.
View attachment 1163421 View attachment 1163422 View attachment 1163424
Lastly, I basically did the exact mod that WESAYSO has posted, but placed the button under the pull handle to protect it from shifting cargo and prying eyes. 10 bucks on amazon for 5 3 position switches with male paddle connectors. Look to their post for details.
Ultimately, I think this recessed button design is the safest when it comes to shifting cargo. It seems very unlikely that anything would poke into a small opening AND push down, so I feel confident I won't lose my cargo all over the freeway. Here's a video of it in operation. Thanks for reading!
Dallas
Late to the party, but have to agree with everyone else; this is awesome!
And thanks for graciously sharing your files. I'll give it a go (y)
Discussion Starter · #33 ·
Hey everybody.
I just popped up to Yosemite to sleep in my truck and try out my latch and came back to this. I'm flattered. I'm pretty busy, but I'm going to try to make these for everyone if you don't mind being a little patient. If all of you who are interested in a set don't mind sending me a PM with your specific colors listed that would be helpful for me to organize this. Please specify if you would like the Handle. It's the longest part to print, so if it's not desired it'll speed up the process for me significantly. So let's format the request like this:
Handle - Yes/No. If yes, Black, Grey, Red, Orange, Blue, or White?
Port color - Black, Grey, Red, Orange, Blue, or White?
Button color - Black, Grey, Red, Orange, Blue, or White?
The internal linkage will be whatever color was on the printer last, but won't be visible. Finally, as everyone has suggested, $20 seems reasonable for the effort, so that's what we'll do. But I'll go ahead and include the aluminum rod already bent to match mine so you won't need any additional materials to install. All snap fit for the release parts.
Thanks!
Dallas
Discussion Starter · #34 ·
Thread STUCK to the top of the section.
Very nice! :cool: I'm in if you're printing and selling. Black or gray preferred.
Supporting Vendor status will not be required for a small run of these.
Thank you!
Hey Hannibal,
I'm embarrassed to say I didn't know anything about vendor rules. Hopefully I'm not bending any. Please let me know if there's anything off-limits. Just trying to make my beloved truck even more beloved and help you fine folks out in the process. D
Dallas
You really did it nicely here. I applaud your ingenuity !!!! WOW!!!!!
Dallas
Gold Star for you
21 - 40 of 64 Posts
