1 - 5 of 5 Posts
Has anyone installed the Pac Intelligent 4 CAM SWTCHR? I'd like to tap into the turn signals to trigger side cameras however not been successful in finding out how. The other two camera inputs would be for reverse and one on a manual toggle either in the front or back. I have a 2008 FJ.
I just pulled mine out to redo and cleanup the wiring last week.
side cameras are mounted in the mirrors, switching cameras to be able to see front tires.
to get them to work with turn signals on the FJ you need to tap the turn signal lever switch directly and you will need a few diodes in line for trigger lines.
Installed hard switches on mine for off road spotting use.
You want to tap the Green with black stripe for left camera and green with yellow stripe for right camera, use the negative triggers. them 2 wires go between the turn signal switch and the flasher
1 - 5 of 5 Posts
