1 - 17 of 17 Posts
so i got my FJ back yesterday from getting my 6 inch fabtech with dirt logic shocks lift done and was driving to a dodger game ( which is about 30 mins from my house freeway driving). anyway i was doing bout 70 on the freeway and hit some bumps on a turn and the green 4x4 light started flashing and never turned off all night. i tried putting it in a 4wd high and low and driving then pulling it back into 2wd but it still kept flashing.
when i drove to work this morning it was not flashing anymore
any idea whay it came on in the first place?
I can see the VSC light come on once in a while, but that's a strange one. Did you get a chance to get under it and take a look? If you didn't find anything, it might be a good time to head back to the installer and see if they know what's going on.
i did look under and i didnt see a problem
and since the light was not on this morning i wasnt gonna take it back just yet
It's a safety issue. I do hope everything is installed correctly. Who did the work? The shop in Azusa?
Discussion Starter · #5 · (Edited)
no
custom truck shop in san dimas.
San Dimas High Football Rules!!!!
wouldnt know but ok
bill and ted rule though lol
Check wheel speed sensors and related connectors.
do you think to much grease when i reinstalled them, would have an effect? other than that I've taken them out and in 3 times already, maybe snaped the wire inside the line while the caliper was off? it did get streached a bit when i put it on the new knuckle.
That may be what's up. We busted the cable to the rear passenger side wheel sensor when breaking a bolt free to swap in new upper links. It was tight as hell and when it broke free, the handle slammed into the wire. If I remember correctly, I had numerous lights go on. ABS, VSC, etc.... If this is the problem, Don't let the dealer tell you you need a new sensor if it isn't actually broken. My sensor was fine... just the wire needed to be replaced. They ended up charging me over $400 for a new wire and sensor, but never told me I could have just ordered the new wire for a few dollars. Don't let them screw you too!
I agree with Fjamming. Have it looked at ASAP to be on the safe side.
thanx, sounds about right, yeah i work at a shop and i just hate having to go to Toyota, even just to buy parts! living on an island at the end of the US makes it hell to get parts in a timely mannor. and even if im in my work shirt they still treat my like im a lesser person!
i new it was something to do with electronics, as ive done lifts on older IFS trucks all the time with no problems.
i saw in another thread that said the cables were like $8 each and the sensors were almost $300 each!
Check the actuator. We managed to hit mine while installing the RC 6 " lift causing the 4x4 to engage. Chris Aka not-his-fj knows his stuff so he opened it and fixed it. It should be in front of the bracket lift. The actuator is what engages the 4x4, so it seems like a more probable cause.
Check the vacume tube on the front diff acutator.
Let us know what you find out
1 - 17 of 17 Posts
