I'm assuming you are looking at something like this trailer (link)
Shouldn't be a problem with it loaded properly. That trailer for example is 1,100lbs empty with a max GVWR of 2,990, either way it should be fine. Just remember to down shift when going down large hills if needed to keep your speed from increasing. Use your brakes as little as possible but when needed. Your engine will rev more than normal when going down hill when down shifted but don't worry unless it's getting over 4K RPMS then you may want to hit the brakes to help slow you down. Don't tow in OD or 6th either.
FWIW, I just pulled a larger 3,200lbs trailer without trailer brakes (or weight distribution hitch) for 3 days through the Rocky Mountains. I have a manual transmission and it easily kept my speed down while going down large hills (note the trailer did have more wind drag than a cargo trailer). Remember that braking distance will be increased with more weight so leave plenty of room in front of you and other cars. My stopping distance was probably about 1.5 times of normal. Not too bad but if you weren't paying attention it could get you when coming to a complete stop.
Also, you probably won't be going over 70-75 even on the Interstate with 3K behind you. Just go slow when needed and be safe. You'll get the hang of it and figure it out quickly.
