1 - 6 of 6 Posts
2008 model and I've noticed the A/C works most times when I first start it up but stops blowing cold, after anywhere from 5-30 min of driving. A/C is set to max cold (almost all summer here in Vegas) and blower to high. Blower fan speed never changes, I just go from having frosty air to warm air out the vents. Every time it fails I turn the blower to "OFF" then back on again. I would say only 20% of the time this actually fixes it. Interestingly, if I park and shut the engine off for a bit then back on the A/C always starts up. Yesterday I changed out the Mag Clutch Relay and thought I had it fixed. The A/C ran fine all the way to work but on the way home it failed about 10 min into driving home. As I've always done before I cycled to "OFF" then as I made the first click back to "ON" I popped 4 different dash lights, "check engine" "VSC Trac", "VSC Off" and the one with the skidding tires. I pulled the code reader out to see if anything shows up and I had two codes: P0117 (ENG coolant temp circuit low input) and C1201 (DTC- ENG control System). Any ideas?
Have you serviced the freon at all? You might also need to replace the actual mag clutch if the relay didn't help, or just the whole compressor.
Have a peak at the a/c line on the condenser in front of rad
You can see It if you pop your hood very visible
Check for kinks/ slight bends
It’s a very flimsy line easy to inspect
1 - 6 of 6 Posts
