Best bet is to place it on ebay. There is a lot of interest there. It will go for $300+. Just sold mine for $355.
Hey bambam, once you get rid of it, you can wire tap into the cables that were supplying power to it, and run a 12volt outlet to the back of the FJ. I did this and put it directly over the a/c outlet. Took about 20 minutes including drilling time.
Are you talking about pluggin in your own sub? I have no idea.Just curious, How many amps on the outlet can you run by using this, i have noticed mine has the plug under the plastic cover..?
bandi said:SOLD SOLD SOLD SOLD SOLD SOLD SOLD
$200 Shipped w/ TRADE of PANELS from Your FJ !... * **
PAYPAL Prefered... Quik and Secure... Also check
my Ebay ratings if needed...
Ebay - 3rtrwalrus
PayPal - walrus42 at comcast dot net
The cover does have some scuffs on it... [edit] I
added images to this post, see below, thank you...
There is nothing wrong with this Sub', it works great,
but I have rarely used it, and I would prefer to have
the extra storage space in the rear area of the FJ...
** - Lower 48 states only please...
** - This does not include the front panel switch...
See HERE for an Ebay Auction of the same Woofer...
Please read note at bottom of this post...
I will need the replacement parts from your FJ to be
able to complete my interior from the removal of the
Sub Woofer assemble (see image below)...
You will get...
1. The complete FJ Subwoofer assemble
2. Four mounting screws/bolts
3. Lower plastic trim panel
You will send me...
1. Two tie down pieces with screws/bolts
2. Upper Panel
3. Lower Panel
4. Upper panel inside Tray
(see detailed parts image below)
Parts Image :
SubWoofer Images :
Detailed parts image :
NOTE: I am a long time member here at the forum,
and I am positive anyone would vouch for me, but
on the other hand, there are alot of people with
lower post counts, and I do not know everybody,
so I will not ship this until I receive the receive the
patch pieces I have listed above... Upon receiving
them, I will ship out the parts that I listed above on
the very next business day and I will promptly send
you the UPS tracking information... Sorry for the
mistrust, but there have been some deals gone bad
here before...
This ad will be listed on other forums and such too...
bandi said:OK... I'll get a pict up in a minute...
White w/ blue Stripe - constant Hot 12v
Gray - Hot with key on 12v
Purple - Hot with sub switch 12v
White w/ black stripe - Ground
yellow - spkr 6v L-
white - spkr 6v R-
black - spkr 6v L+
red - spkr 6v R+
You will need to cut the purple wire, and connect
it to the gray, leaving the purple to the chassis
disconnected and taped off...
